825
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. G_sam_sam_VxnY
    Cupcake Sep 18, 2019
  2. Swejuggalo
    KitKat Sep 18, 2019
    Swejuggalo , Sep 18, 2019 :
    Checked my links above? Because you need to be able to understand those methods to upgrade and the last one to be able to revert to 9.
    You most certainly have issue with the file ending with jar and not zip. Rename and move file to right directory or learn to use Oxygen Updater and you get the file to the right directory and with the right file extension right away.
    G_sam_sam_VxnY likes this.
  3. atLeeroyJenkins
    Froyo Sep 18, 2019
    atLeeroyJenkins , Sep 18, 2019 :
    It seems the back gesture sensitivity option that is available on pixel and was in the developer previews is now gone. Wonder why, it was helpful
  4. G_android_x14
    Gingerbread Sep 18, 2019
    G_android_x14 , Sep 18, 2019 :
    the build.prop file is a config file. why would you expect it to change? it should be close to identical even between versions of android.
    do a diff on binaries or source code, then you will see changes.
  5. docnok63
    Ice Cream Sandwich Sep 18, 2019
    docnok63 , Sep 18, 2019 :
    I've been doing this since DP3 and this is the first time it hasn't changed.
  6. G_android_x14
    still, not indicative of what bits have changed.
  7. docnok63
    No, not the software itself but the direction they're trying to steer the software. The build.prop is literally a config file for the Android OS on the device. Any changes there are system-wide. Changing one line from true to false or commenting out a few lines can have a dramatic effect on the device.
    Georgeoneplus7pro likes this.
  8. G_android_x14
    all true, but I expect most major config changes to be done by the time an open beta hits. open beta should be all about stability and quashing bugs before general release. configurable features should be set. changes to configurable features just extend the testing cycle.
    docnok63 and Georgeoneplus7pro like this.
  9. JmcRepair33
    Honeycomb Sep 18, 2019
    JmcRepair33 , Sep 18, 2019 :
    You dont have to appologize to that guy. he doesnt even know where he is, not the boss here. Your good brother you didnt know
  10. JmcRepair33
    Did it occur to you to look at the first post?
    RandyManLB likes this.
  11. atLeeroyJenkins
    Froyo Sep 18, 2019
    Open Beta 2 is much much better, much snappier, the jank and random freezes are a lot less, still happen under very heavy use (wasn't on Pie) but I'd consider this a near release candidate. It's very stable. No crashes, no problems just a tiny bit of jank here and there that's it.
    3 criticisms:
    1. Please for the love of God adopt the Android 10 style of icons with the outlines, the Pie aesthetic mixed with 10 just looks odd and inconsistent.
    2. Why is the Android 10 gesture navigation sensitivity option gone? It makes no sense removing it and on my work Pixel devices I found it extremely important in adjusting it to preference.
    3. The Incostistant dark theme needs to be fixed. Some areas are black (which it should be) and then some like the drop-down menu is dark gray.
    All in all it's great and I have a feeling next update will be the release.
    Cheers
    Pokemon Master Leeroy
    docnok63 likes this.
  12. H1509642441700
    H1509642441700 , Sep 18, 2019 :
    Jio tv app not opening in Android 10 beta 1 on oneplus 7..app opening but not logging in with jio sim...pls look on this
  13. lethaltricks
    lethaltricks , Sep 18, 2019 :
    Same issue. It's most to the point where I'm going to downgrade bc I use Bluetooth for music for hours every day. Tried re-pairing devices several times and no dice. Hopefully it's fixed..
  14. Dgafking0480
    Dgafking0480 , Sep 18, 2019 :
    if you have issues please report them in the feedback section
  15. JmcRepair33
    You would have to contact the Jio develepors and send them a log cat of the app so they can get the errors so they can make it work with our phones
  16. JmcRepair33
  17. JmcRepair33
    Figures Pokemon Gamer
  18. vinod_sonu
  19. Sigmanp320x
    Sigmanp320x , Sep 18, 2019 :
    well something has changed for sure. beta 2 has more issues that beta 1. clean install.
    Netflix don't work
    some bank apps don't work
    magisk no longer roots device for me or on 9.5.13 always fails to root via mobile
    YouTube has issue intermittent
    guess I'll roll back to stable until. final build as I leave me keeping root and not sure why it won't keep root now
  20. Swejuggalo
    KitKat Sep 18, 2019
    Netflix works fine here (a not rooted 7 Pro) ... Upgraded from OB1. Some posted info from Google play with unsuppoeted device warnings and stuff. Some had this on OB1 and might even seen it on stable too.
    Some got same issue on OB1 too with YouTube. Not sure on stable though.
    Sigmanp320x likes this.
