844
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. G_sam_sam_VxnY
    Cupcake Sep 20, 2019
  2. Swejuggalo
    KitKat Sep 20, 2019
  3. G_sam_sam_VxnY
  4. G_sam_sam_VxnY
  5. Dgafking0480
    Ice Cream Sandwich Sep 20, 2019
  6. Swejuggalo
    KitKat Sep 20, 2019
    Swejuggalo , Sep 20, 2019 :
    Check your list of disabled apps. Maybe you disabled Contacts by mistake
    Dgafking0480 likes this.
  7. Swejuggalo
    KitKat Sep 20, 2019
    Settings, apps and notifications, see all apps. Select disabled apps
  8. JmcRepair33
    Honeycomb Sep 20, 2019
    JmcRepair33 , Sep 20, 2019 :
    You really deaf and im tellling you HOW IT IS OR CAN YOU NOT READ CORRECTLY?
  9. V1567187491524
  10. JmcRepair33
    You can do it if not get a tmobile phone yourself and try it i know what im talking about, im not going to lie i DID it myself. Unless tmobile sold me a international version on Tmobile firmware........ no i dont think so. If you havent tried it yourself dont talk and say things you havent done. I know for a fact and did it when it was not unlocked. Jesus Drop it . First try it and you will see. a locked Tmobile phone, Flash the converter to international on your computer then download the Beta and install on the LOCAL UPGRADE after taking out he .jar file and moving it to internal root folder. PERIOD. Guarantee it will work BECAUSE I DID IT. You dont have to be a rocket scientist, I CHALLENGE ANYONE with a locked Tmobile phone to try it, IF it doesnt work then call me a liar. I cant stand people that like to talk when they dont evebn know what they are talking about and just what they read from other people that THOUGHT that you have to be unlocked. And i clarified them in those forums whenthey mentioned it about a month look back in the forums. When you Try it and see it doesnt work after converting to international then call me a liar. I know it works 100% Dont ask dot mention anything unless you Know WTF you talking about. I hate wanna be haters
  11. Dgafking0480
    Dgafking0480 , Sep 20, 2019 :
    dude the funny thing is you're talking to someone who had a locked TMobile phone and it DID NOT. work there are many people here who have flashed international version and try to install dp3 dp4 and dp5 and had no service on any version of that so yes I will call you a liar and there are many people who have done the same thing and had no service on a locked T-Mobile phone I know firsthand that it does not work
    docnok63 likes this.
  12. Aman800
    Aman800 , Sep 20, 2019 :
    Unfortunately I have to report a bug with my Bluetooth connection, I own a oneplus 7 and it's frequently disconnecting from my Bluetooth earphones and car Bluetooth, also some time it gets connected to a ghost Bluetooth connection, with no name, when I try to increase volume then only my phone shows it's connected to Bluetooth, but Bluetooth isn't even on.. please try to fix it in next update.
    For a phone without 3.5mm jack it's a real problem
  13. G_sam_sam_VxnY
  14. JmcRepair33
    Well looks like you didnt do it right. i know what i have and i dont have any special software thats not in xda. everything is in xda and i know what i did and WHEn i unlocked my phone i was already in dp4 and my phone was still locked, guess my phone has magic
  15. Dgafking0480
    what worked for you may not work for others is what we're getting at, like I said before most people need to be sim unlocked in order to have service and not get the sim locked messaged when flashing to ob
  16. JmcRepair33
    ILL TAKE THAT AS A REPLY.
  17. Daniel J Chris
    Cupcake Sep 21, 2019
  18. Gav_W86
    Starting Point Expert Sep 21, 2019
  19. Daniel J Chris
  20. Asish Behera
    Honeycomb Sep 21, 2019
    Asish Behera , Sep 21, 2019 :
    To rollback do I need to extract .zip file from the .jar or the .jar can directly be flashed?
