826
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. Asish Behera
    Honeycomb Sep 21, 2019
    Asish Behera , Sep 21, 2019 :
    To rollback do I need to extract .zip file from the .jar or the .jar can directly be flashed?
  2. Swejuggalo
    KitKat Sep 21, 2019
    Swejuggalo , Sep 21, 2019 :
    Asish Behera
    To rollback do I need to extract .zip file from the .jar or the .jar can directly be flashed?​
    Remove jar. Should only be zip. No extract needed
  3. Nick_Amina
    Froyo Sep 21, 2019
    Nick_Amina , Sep 21, 2019 :
    Hello, I can't find the update file in the specific location (Local upgrade). I copy the package in the phone storage!!!
  4. SchmilK
    Eclair Sep 21, 2019
    SchmilK , Sep 21, 2019 :
    right on - but now I know how to extract :)
    docnok63 likes this.
  5. Mariodew
    Donut Sep 21, 2019
    Mariodew , Sep 21, 2019 :
    the rollback file is a .zip.jar file. and it doesn't show up on lokale upgrade. will it show up when i put it in main storage? sorry for not reading ... has been asked before
  6. Dgafking0480
    Ice Cream Sandwich Sep 21, 2019
    Dgafking0480 , Sep 21, 2019 :
    rename the file and only delete the .jar from the name and place it on the root of the phone
  7. M1559669665478
    Cupcake Sep 21, 2019
    M1559669665478 , Sep 21, 2019 :
    The timing not matching while we sing songs smule and starmaker apps. Both smule and starmaker applications voice is delaying with music.plz suggest....
  8. M1559669665478
    The timing not matching while we sing song in smule and starmaker. both smule and starmaker applications voice is delaying with music.plz suggest
  9. D1569082810049
    D1569082810049 , Sep 21, 2019 :
    I have the Tmobile OP7Pro on the International stable Rom 9.5.13. I previously installed OB1 but had the "unlock" issue that rendered my phone radio unusable. Will this still be an issue on this stable Android 10 upgrade?
  10. Dgafking0480
    shouldn't be a issue when stable is released, TMobile has to do their testing on the version before they release it
  11. G1569093523895
  12. D1569082810049
    I am not using the Tmobile ROM.
  13. Slicktune
    Slicktune , Sep 21, 2019 :
    I am on OB2, do I need to roll back to pie to update to Android 20 stable release? thanks in advance
  14. SlimJimmy
    Donut Sep 22, 2019
    SlimJimmy , Sep 22, 2019 :
    Hey I also have a Tmobile 7 pro converted to International. The radio issue was fixed on OB2.
    Dgafking0480 likes this.
  15. KamalJat808
    Cupcake Sep 22, 2019
    KamalJat808 , Sep 22, 2019 :
    I m not able yet I have downloaded roll back package
    for Android pie 9 , I followed instructions correctly but all is vain.
  16. SHEUL
  17. Cervantes
    Lollipop Moderator Sep 22, 2019
    Cervantes , Sep 22, 2019 :
    In theory it should work OBT1
    it is a program that deletes the contents of the telephone and installs a rom
    in OBT2 suggests a clean installation
  18. KamalJat808
  19. SHEUL
    SHEUL , Sep 22, 2019 :
    How to clean install, can you please tell us those steps?
  20. Cervantes
    Clean installation
    download the rom, and copies in the internal storage
    turn off press volume less and on
    you go into recovery
    english, wipe data and cache
    wipe data, done
    wipe cache, done
    do not restart after wipe
    local installation, look for the zip
    restart
    You have tutorials on youtube
