875
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. Gaurav_Singh1559
    Cupcake Oct 4, 2019
    Gaurav_Singh1559 , Oct 4, 2019 :
    After installing android 10 beta 1 in my op7pro
    I downgrade to android pie should I get official update through ota or not
  2. Cervantes
    Moderator Moderator Oct 4, 2019
    Cervantes , Oct 4, 2019 :
    Hi
    It is written in the instructions of the first post
    "*Moving back to the Official OTA path from the Beta path will require a full install and clean flash (full wipe of all data and cache).
    *"The update or beta thread is a thread of questions and/or commentary"*
    Thread merged
  3. Kunal974
    Cupcake Oct 4, 2019
    Kunal974 , Oct 4, 2019 :
    I didn't get official upgrade of Android 10 for OnePlus 7
    when we are expected to launch the official update
  4. Deactivated User
    Oct 4, 2019
  5. G1570201446593
    Cupcake Oct 4, 2019
  6. suniel sharma
    Cupcake Oct 5, 2019
  7. Vattsal Singhal
    Cupcake Oct 5, 2019
  8. G_Jayanth_jay 157
    Cupcake Oct 6, 2019
  9. G_Jayanth_jay 157
    Cupcake Oct 6, 2019
  10. piyush singh
    Cupcake Oct 6, 2019
  11. Hunter of souls
    Cupcake Oct 6, 2019
    Hunter of souls , Oct 6, 2019 :
    I had a problem with big battery drain. 2 % per hour. I tried all settings of my OP 7 Pro and 15 apps but nothing can't helped me. But now I found 2 apps which fixed my battery drain. About the system in used Repair system and Fix Android problems ! After that for drain used Q Battery Doctor - Battery life saver. Good luck guys hope that this will help you.
  12. U1570138479019
    Cupcake Oct 6, 2019
  13. R1570451016107
    Cupcake Oct 7, 2019
    R1570451016107 , Oct 7, 2019 :
    No drain with these 2 apps :) and optimisation work perfect. Oxygen 10 with app Oxygen updater ...
  14. K1569966749125
    Cupcake Oct 7, 2019
    K1569966749125 , Oct 7, 2019 :
    Is the one plus 7 pro 5g from sprint able to test the beta? From my understanding I don't think they are considered the same. I just got this phone and I am having slow internet speed unless I turn on my Hotspot. I heard the upgrade to Android 10 might fix this
  15. R1570451016107
    Cupcake Oct 7, 2019
  16. R1570451016107
    Cupcake Oct 8, 2019
  17. red80
    Donut Oct 8, 2019
  18. R1570451016107
    Cupcake Oct 9, 2019
    red80 likes this.
  19. Q1535883193946
    Cupcake Oct 9, 2019
    Q1535883193946 , Oct 9, 2019 :
    well, thank you Oneplus for NOT providing the new android 10 on Onplus 6, guess im changing back to Samsung
