836
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. docnok63
    Jelly Bean Sep 4, 2019
    docnok63 , Sep 4, 2019 :
    No, Open Beta is a separate path than Stable version and once you are on one path, you'll need to do a full wipe to go to the other except for the first time (stable to open.)
    https://forums.oneplus.com/threads/oxygenos-beta-program-explained.469761/
  2. VaibhavBhargava
    Lollipop Sep 4, 2019
    VaibhavBhargava , Sep 4, 2019 :
    You can disable the fingerprint animation altogether
  3. syedrhashmi
    Froyo Sep 4, 2019
  4. VaibhavBhargava
    Yes, they did. Infact this is their debut phone.
  5. ShrikeAbyssal
    Cupcake Sep 4, 2019
    ShrikeAbyssal , Sep 4, 2019 :
    The open beta thus far has been relatively stable, aside a few visual hiccups with YouTube in PIP mode. The update did bork my Bluetooth connections a tad and had to remove and add back some of my devices to have them auto-connect again. My Lancer's stock bluetooth headunit won't connect to the phone properly: it either connects but fails to import contacts and media playback doesn't work or it doesn't connect at all despite having set the PIN code to 0000. I figured the beta build was the cause as my phone was connected just fine before the update and some of my similar Bluetooth devices that aren't using 5.0 or at least 4.x are having some issues with connections.
  6. _Bathula_SharathKumar_
    Cupcake Sep 4, 2019
  7. docnok63
    Read the top part of the first post warning you that it's not. For some/most yes, for some no. It depends on your experience with flashing builds, recovering from bad situations, and tolerance level for bugs.
  8. JayantMorghade
    Froyo Sep 4, 2019
    JayantMorghade , Sep 4, 2019 :
    Definitely not for me then...
  9. G_Rishabh_Srivastava_jRl
    Eclair Sep 4, 2019
    G_Rishabh_Srivastava_jRl , Sep 4, 2019 :
    Just installed the OB version. I see a lot of updates in the camera. Wide angle support for video, and Nightscape. But the quality has gone down :/
  10. Harirev
    Eclair Sep 4, 2019
    Harirev , Sep 4, 2019 :
    no.its open beta 17 for the OP 6T.
  11. Shevach
    Froyo Sep 4, 2019
    Shevach , Sep 4, 2019 :
    any fix for the text now showing up problem it's only some times so it's weird
  12. H1564335160898
    Cupcake Sep 4, 2019
  13. docnok63
    Unlock developer options, search settings for A2DP and disable Bluetooth A2DP hardware offloading
  14. X1566491693848
    Cupcake Sep 4, 2019
  15. Shevach
    Froyo Sep 4, 2019
    click the link and maker sure to save it in the main folder not downloads
  16. preth.ns
    Cupcake Sep 4, 2019
  17. PrinceKamal
    Froyo Sep 4, 2019
    PrinceKamal , Sep 4, 2019 :
    I Have A question.. I am on latest stable version and now I am going to update this beta version.. then when the stable version will be released then will it come by ota or i have to do local update the same way i did with one.. or it will come in system update?
    Nil2010 likes this.
  18. Jai R Prasad
    Donut Sep 4, 2019
  19. X1566491693848
    Cupcake Sep 4, 2019
    X1566491693848 , Sep 4, 2019 :
    main folder like?
  20. PrinceKamal
    Froyo Sep 4, 2019
