844
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. juustomies
    Eclair Sep 4, 2019
  2. naikjeevan
    Froyo Sep 4, 2019
    naikjeevan , Sep 4, 2019 :
    when it's stable
    T1559745100170 likes this.
  3. ascent
    Honeycomb Sep 4, 2019
    ascent , Sep 4, 2019 :
    whoa.. on my work dock, it works. just not at home. interesting!
  4. raghujana
    Froyo Sep 4, 2019
    raghujana , Sep 4, 2019 :
    It has just been an hour since I installed the OB. Looks good overall, but bugs abound.
    Issues found so far:
    1. Google Translate, tap to translate does not work. The button does not pop up when text is copied.
    2. In Telegram, the colors are messed up when Force-dark is set to always on.
    3. Keyboard has gap at the bottom.
    4. Keyboard does not automatically capitalize first letter after period. keeps it lower case.
    5. Forced dark mode does not work on parallel apps.
    6. Forced dark mode messes up profile pics on Facebook.
    7. Camera lost macro mode.
  5. W1561179925247
    Donut Sep 4, 2019
  6. Nagesh_Pattanshetty
    Froyo Sep 4, 2019
    Nagesh_Pattanshetty , Sep 4, 2019 :
    I've noticed a few bugs.
    1) The recent apps screen doesn't feel as great as it used to be on pie. It's not smooth and it feels elastic. The clear all button at the bottom is annoying. I accidentally touch it every time now and the app gets lost. Also with the one plus gestures for navigation, I saw that when I accessed the recent apps, the widget on my home screen came on top of the recent apps screen on Nova launcher.
    2) The suggestions in the settings cannot be swiped away. It has been telling me to turn on mobile data and I can't get rid of that suggestion in the settings menu.
    3) The settings menu kinda feels cluttered than on pie. This might just be me but I felt that it was better on pie.
  7. pratzzz
    Froyo Sep 4, 2019
    pratzzz , Sep 4, 2019 :
    If you are on stable build right now then when the android 10 stable build is released it will come as an OTA,if you want open beta build right now then download the beta and follow the instructions in the first post as to how to install it and thereafter you will only receive open beta builds as an OTA.
    wonderer_007 likes this.
  8. DelBoyJamie
    Froyo Sep 4, 2019
    DelBoyJamie , Sep 4, 2019 :
    When did the onepus 7 Pro have "Macro Mode"
    Krzysztof 77 likes this.
  9. nipuna001
    Eclair Sep 4, 2019
    nipuna001 , Sep 4, 2019 :
    just curious if the dock charges the phone when connected to power? given the power drain, to use as a desktop replacement, we'd need power delivery to the phone..
  10. Haidar Ali
    Gingerbread Sep 4, 2019
  11. TARIQUE807
    Eclair Sep 4, 2019
  12. Nagesh_Pattanshetty
    Froyo Sep 4, 2019
    Few more bugs.
    1) Force enable dark mode messes up some apps
    2) There's a gap at the bottom of the keyboard with the gestures enabled.
    3) Letters don't get capitalised after the full stop.
    4) Swipe to the top to get rid of an app in the recents menu isn't smooth. I've to swipe all the way to the top instead of a flick to make it disappear from the recents menu.
  13. JigneshJain
    JigneshJain , Sep 4, 2019 :
    the suggestion appear only if person ask questions or the answer is yes or no types.
    also you can check notification bubble is on or not from developer setting
    Rajat Rangdal likes this.
  14. JigneshJain
    install manually
  15. Petzkub
    Froyo Sep 4, 2019
    Petzkub , Sep 4, 2019 :
    People, plz.
    1. Read the OP. And then read it again.
    2. Use search, your question has been asked and answered 50 times already.
    3. If you have a question is about any other device than the OP7 / OP7 Pro, you are in wrong thread.
    And calm down. The beta was just released. Dont ask ETAs for stable release. If there is info about upcoming releases, I think youll find the info about that in the op-forums via search. If not, there is no info about next release.
    Thanks and sorry.
  16. JigneshJain
    it needs to be downloaded and installed no ota
  17. Z1565964505801
    Donut Sep 4, 2019
    Z1565964505801 , Sep 4, 2019 :
    Hi hope someone can help I pressed on the above link 7 pro beta update but for some reason only a blank screen with an arrow and three dots appear?
    Any help would be appreciated, first time doing this.
    Thank you
    Pf
  18. JigneshJain
    select 3 dots on right hand side and open in browser to download
  19. ascent
    yep, it charges for me!
    JigneshJain likes this.
  20. JigneshJain
    any screenshot how desktop mode looks?
