875
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. H1561960043803
    Ice Cream Sandwich Sep 4, 2019
    H1561960043803 , Sep 4, 2019 :
    nope
  2. W1564051536574
    Donut Sep 4, 2019
    W1564051536574 , Sep 4, 2019 :
    How do I move the file from my downloads into the root folder? It's not showing where to move it to
  3. Nagesh_Pattanshetty
    Gingerbread Sep 4, 2019
  4. H1561960043803
  5. Poussin16
    Poussin16 , Sep 4, 2019 :
    hi all ,
    can you please advise if desktop mode is on Android 10 update?
    I only found old comments about it, only 1 video posted currently.
    thanks
  6. pandiz
    Donut Sep 4, 2019
  7. charmingash
    Honeycomb Sep 4, 2019
    charmingash , Sep 4, 2019 :
    it happened in developer preview 3 too they didnt fixed it i think its because of angle api.
    N1cK01 likes this.
  8. Tanaypande
    Donut Sep 4, 2019
    Tanaypande , Sep 4, 2019 :
    Unable to use no one banking of any bank..
    It's showing sim card not found.. Please insert Sim and try again..
  9. Ram Sundar R
    Donut Sep 4, 2019
    Ram Sundar R , Sep 4, 2019 :
    Display goes suddenly off when i opened pubg... After i force reboot , the display turns on
  10. charmingash
  11. awes0me1
    awes0me1 , Sep 4, 2019 :
    I installed but then reverted back to Pie, it just doesn't seem as fluent and the dark mode is a little hit and miss. It is still in Beta so I'm not complaining, problem is I also own a Pixel device which has Stable Android 10 and I can compare the two and the difference is huge. OnePlus will get there, its just missing the mark at the moment. :)
    BeansnCornbread likes this.
  12. Tejarshi31
    Cupcake Sep 4, 2019
  13. charmingash
    yep annoying bug
  14. H1567595602317
    Cupcake Sep 4, 2019
  15. charmingash
  16. awes0me1
    Your problem has been talked about 50+ times already, read back and you will find your solution :)
    Petzkub likes this.
  17. Garvit01
    Froyo Sep 4, 2019
  18. jeevan_naik
    jeevan_naik , Sep 4, 2019 :
    It's Open Beta, available globally. download from given link.
    Am from India too, I downloaded from given link for OnePlus 7 Pro & using it.. no issues yet except banking apps (unable to login, might be temporary).
  19. P1567437735637
    Donut Sep 4, 2019
  20. Petzkub
    Froyo Sep 4, 2019
    Petzkub , Sep 4, 2019 :
    If you are struggling with moving a file inside your phone to a right folder. Maybe, just maybe you shouldnt be installing beta software on your phone.
    rweckhoff, R_d_M, bandit1976 and 4 others like this.
