875
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. div28
    Cupcake Sep 4, 2019
    div28 , Sep 4, 2019 :
    everyone does that by removing the app running in background.
  2. iampun33t
    Gingerbread Sep 4, 2019
    iampun33t , Sep 4, 2019 :
    Banking as working fine. You just need to force close (or clear data) them and re-authenticate them.
  3. Anusan12
    Froyo Sep 4, 2019
    Anusan12 , Sep 4, 2019 :
    can't see the option of notch display in the Android 10. what did I install man
  4. Computman
    Emank likes this.
  5. iampun33t
    Android does not work that way. Its not windows which needs free RAM. Also 6 GB RAM is more than enough for anything you would ever want to do, and do it smoothly.
  6. hossain1993
    Cupcake Sep 4, 2019
    hossain1993 , Sep 4, 2019 :
    I tried upgrading but for some reason my OP7 pro isn't able to locate the update. I don't even have the option to check local storage update....
  7. ascent
    Honeycomb Sep 4, 2019
    ascent , Sep 4, 2019 :
    Maybe it's best to wait for stable ota then....
    ... of which we don't know when it'll arrive:)
  8. Georgeoneplus7pro
    Jelly Bean Sep 4, 2019
    Georgeoneplus7pro , Sep 4, 2019 :
    Lifetime updates, should for OnePlus 5.
  9. momorious
    Donut Sep 4, 2019
    momorious , Sep 4, 2019 :
    I have a problem: After install my notifications were black which was pretty cool as I am using Dark Mode. However, after I read that in dev options you can force every app to use dark mode I tried that but it didn't looked good with every app so I turned that setting off again. And now my notifications are all white and I only can get them black again when using this option to force all apps to use dark mode again which I don't want to use.
    Anyone knows a solution for this how to get black notifications back without the need of the dev option? Already tried a re-install of this beta but it didn't worked as well :(
  10. iampun33t
    No one knows. Maybe in a couple of weeks. Also, It's Android 10 not Q.
  11. Petzkub
    Froyo Sep 4, 2019
    Petzkub , Sep 4, 2019 :
    PLZ, use search.
    iampun33t likes this.
  12. RaviJaya7
    RaviJaya7 , Sep 4, 2019 :
    please copy the download file and paste on internal storage after it's came on local update
  13. hossain1993
    Cupcake Sep 4, 2019
    I tried copying to internal storage but that didn't work. still unable to access local updates.
  14. JmcRepair33
    Ice Cream Sandwich Sep 4, 2019
    JmcRepair33 , Sep 4, 2019 :
    the 7 t is not going to be worth it from my point of view.
    Sai KrishnaD and ascent like this.
  15. JRach
    Cupcake Sep 4, 2019
    JRach , Sep 4, 2019 :
    no idea what to look for, find nothing
  16. JmcRepair33
  17. iampun33t
  18. JmcRepair33
  19. g.arjun
    Eclair Sep 4, 2019
    g.arjun , Sep 4, 2019 :
    Yes that is true. You can perform a local upgrade and not loose any data
  20. M1561389735830
    Donut Sep 4, 2019
