875
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. ZeeKinio
    Cupcake Sep 4, 2019
    ZeeKinio , Sep 4, 2019 :
    i find it horrible why they need this space
  2. Georgeoneplus7pro
    Jelly Bean Sep 4, 2019
    Georgeoneplus7pro , Sep 4, 2019 :
    If you only have 6GB RAM, you're right. But this is only for your soul.
  3. JmcRepair33
    Ice Cream Sandwich Sep 4, 2019
    JmcRepair33 , Sep 4, 2019 :
    Man good for you, POST IN THE RIGHT FORUM> WHY DO WE CARE?
  4. JmcRepair33
    I do have a extra controller that would be nice
  5. ascent
    Honeycomb Sep 4, 2019
    ascent , Sep 4, 2019 :
    you're in the wrong screen I think .... "system updates" -> threedot -> local upgrade, instead of this screen
  6. F_Tejaswi_Tingi_bkVl
    Eclair Sep 4, 2019
  7. ascent
    Could well be, as mouse and keyboard using a dock sometimes works too now!
    M1561389735830 likes this.
  8. F_Tejaswi_Tingi_bkVl
    Eclair Sep 4, 2019
    F_Tejaswi_Tingi_bkVl , Sep 4, 2019 :
    I meant for the OP7 Pro. I too am on the Open Beta for the OP7 Pro.
    Sorry I missed out on that detail.
  9. div28
    Cupcake Sep 4, 2019
    div28 , Sep 4, 2019 :
    have you ever removed the app in the background. when you're not using them?
  10. Georgeoneplus7pro
    Why? If you didn't have 7Pro, would it be worth it?
  11. ascent
    Which apps?
  12. g.arjun
    Eclair Sep 4, 2019
    g.arjun , Sep 4, 2019 :
    Had anyone tested these features with latest DP5. I had to rollback from DP4 earlier as the following features weren't working
    1. Google Auto
    2. MI Band notifications
    3. System wide Dark theme integration with Applications
  13. div28
    Cupcake Sep 4, 2019
    how to remove the extra space below the keyboard? can anyone tell
  14. rushabhgala
    Donut Sep 4, 2019
    rushabhgala , Sep 4, 2019 :
    can you add a way to change accent colour by adding the hex code? manually sliding to getting it right is a task
    Huigiebaby likes this.
  15. M1561389735830
    Donut Sep 4, 2019
    M1561389735830 , Sep 4, 2019 :
    I have the powerlead pg-9118 controller.
    it's a good one, but the button light is annoying
    and the PS4 controller have more quality.
  16. bandit1976
    Gingerbread Sep 4, 2019
    g.arjun likes this.
  17. M1561389735830
    Donut Sep 4, 2019
    GREAT![e]1f64f[/e] i have wating for this so long
    thank you for you answer [e]1f60a[/e]
    ascent likes this.
  18. rushabhgala
    Donut Sep 4, 2019
    turn off force dark
    go to settings ->customization->nuanced dark
    and reboot
  19. giaur500
    giaur500 , Sep 4, 2019 :
    Open Beta may be cool, but when should we expect stable ota update to Android 10?
  20. iampun33t
    iampun33t , Sep 4, 2019 :
    Just clear Chrome when I am done with it. Sometimes not even that. Haven't cleared any other app, anytime. Its completely unnecessary and then needs more resources to open it again when needed. So, whats the point. RAM management in Oneplus and Android is great, in any case.
