874
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. iampun33t
    Gingerbread Sep 4, 2019
    iampun33t , Sep 4, 2019 :
    Just clear Chrome when I am done with it. Sometimes not even that. Haven't cleared any other app, anytime. Its completely unnecessary and then needs more resources to open it again when needed. So, whats the point. RAM management in Oneplus and Android is great, in any case.
  2. div28
    Cupcake Sep 4, 2019
    div28 , Sep 4, 2019 :
    no need to open any other resource. you can remove the apps from multi tab functioning.
  3. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 4, 2019
    Swejuggalo , Sep 4, 2019 :
    Just in case something is unclear... DP4/5 get OTA to OB1. OB1 only get future OB updates. You need to revert to get back to stable build. Only stable builds get stable updates.
    H1561960043803 likes this.
  4. lavara123
    Cupcake Sep 4, 2019
  5. momorious
    Donut Sep 4, 2019
    momorious , Sep 4, 2019 :
    OH you saved my life, thank you, this worked!!! :)
  6. iampun33t
    Mi Band notifications work. Reinstall the app.
    Force Dark theme from Dev Options to use dark theme in all apps.
    Its an Android 10 or Gboard thing. It cannot be removed as of now.
    g.arjun likes this.
  7. G_peter_dryden_WfVe
    Froyo Sep 4, 2019
  8. iampun33t
    You might want to look for it in the OnePlus 6 thread. I mean, I wouldn't go to Galaxy S10 forums, looking for an update link for Galaxy S8.
  9. G_peter_dryden_WfVe
    Froyo Sep 4, 2019
    G_peter_dryden_WfVe , Sep 4, 2019 :
    I agree we pay more but get less!!
  10. Marcstang04
    Marcstang04 , Sep 4, 2019 :
    I know this isn't a OnePlus issue but a Google issue, I am interested in finding out if anyone has any info on why Google Backup doesn't work on my OP7 Pro(beta) or my Google Pixel 3XL(official build). I would like to do a backup to Google Drive in the event I have to wipe my phone before updating to a official Android 10 build, or if I chose to go back to android 9.
  11. iampun33t
    Well, you paid for 5G and you got 5G. anyway, just wait, 5G Version will be updated soon.
  12. ascent
    Honeycomb Sep 4, 2019
    ascent , Sep 4, 2019 :
    Not there yet, this is the Op7 thread.
  13. g.arjun
    Eclair Sep 4, 2019
    g.arjun , Sep 4, 2019 :
    Thaks for your feedback on Dark Theme. However, my concern was with complete integration with apps such as Amazon, where the images on the app look weird as the software is trying to differentiate between what is text, and what is image. Due to this, the the app looks pretty messed up
  14. huskyuk
    Donut Sep 4, 2019
    huskyuk , Sep 4, 2019 :
    Hi! Any compatibility issues with usual applications so far? How is the battery consumption? Is it stable enough, or should we wait for an official OTA?
  15. Georgeoneplus7pro
    Jelly Bean Sep 4, 2019
    Georgeoneplus7pro , Sep 4, 2019 :
    At the train station and at the market, because there is no 6G signal elsewhere
  16. falconmoonpunch
    falconmoonpunch , Sep 4, 2019 :
    JigneshJain
    Thank you appreciated.
    OnePlus Did a Great Job providing latest version of Android Q.
    some New features added into Q are
    1. Force Override Dark Mode in all Apps can be selected under developer settings
    2. Navigation Gestures Left and Right Swipe keeping OnePlus gestures Intact. cool option
    3. Digital Wellbeing and parental Controls
    4. Icon looks great
    5. Major System UI overhaul
    Installation is easy as shown in Opening Post.
    however if you already have TWRP and rooted just follow this steps;
    1. Boot TWRP
    2. Install Zip
    3. Install Magisk
    4. Install TWRP
    5. Reboot system
    6. Reboot TWRP
    7. Install magsik again
    8. Wipe Cache and Reboot.
    if you follow steps correctly you will boot to Beta Version with root working.
    if you want to have visual guide for installation or watch Video of Beta 1 message me for the Link
    Mod Edit: Media link removed
    You actually just have to flash the update, flash twrp, reboot recovery, flash magisk, wipe cache or factory reset (user preference for reset, I always factory reset before booting to a new OS or after any major update)
  17. Suhaas Nandeesh
    Cupcake Sep 4, 2019
    Suhaas Nandeesh , Sep 4, 2019 :
    Installed open beta on OP7(primary device). Working fine with no issues as of now in any of the apps that I am using. One correction in the steps is that factory reset for open beta upgrade is not necessary as mentioned in point 5.
    Just for fun, ran geekbench 4 and geekbench 5 after updating to android 10. Below is the result,
    Geekbench 4
    Geekbench 5
    Not sure why such a big difference in the results.
  18. iampun33t
    Yup. The forced Dark Theme doesn't look great on many apps, thus stopped using it after a few minutes. App devs would need to update their apps for it to look good.
  19. JoseGarciaPM
    Cupcake Sep 4, 2019
  20. basspass
    Froyo Sep 4, 2019
    basspass , Sep 4, 2019 :
    it's because of Android 10 bar underneath the keyboard. if you change gestures it stays there. maybe the next update it well be fixed.
    there is an arrow underneath on there left side.
    if you change gestures it stays the same without the arrow and the line.
