848
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. CodeElixir
    Gingerbread Sep 4, 2019
    CodeElixir , Sep 4, 2019 :
    Wiping dalvik will wipe data in a/b system.
  2. SIDDHARTHA THAKUR
    Cupcake Sep 4, 2019
  3. ranaharishdev
    Eclair Sep 4, 2019
    ranaharishdev , Sep 4, 2019 :
    two file manager ,one default and one more , 2 Google play.
    i m feeling bad after beta os update
  4. akks
    Jelly Bean Sep 4, 2019
    akks , Sep 4, 2019 :
    No-one knows here. Oneplus hasn't revealed any tentative dates.
  5. chrisdarnel
    Cupcake Sep 4, 2019
    chrisdarnel , Sep 4, 2019 :
    installed OB1 via twrp, flashed twrp installer and flashed magisk.
    rebooted as stated in the first few post and now twrp is no longer asking for password and shows internal as 0mb with failed to mount
    how to fix this without wiping and starting over.
  6. akks
    Follow the first post to go back to pie
  7. anasmhds
    Froyo Sep 4, 2019
    Covrivov likes this.
  8. Sridharan_Sivaraman_S
    Cupcake Sep 4, 2019
    Sridharan_Sivaraman_S , Sep 4, 2019 :
    got my mistake I was trying to install the update without moving the package to root directory.. i.e. direct from download folder..
    now installed..
    falconmoonpunch likes this.
  9. pratzzz
    Froyo Sep 4, 2019
    Lahiru Rashinda and Parth0085 like this.
  10. 1MaKo3
    Donut Sep 4, 2019
  11. akks
    Still don't keep over expectations in a beta release. Also 3rd party apps may need optimisation for Android 10, by the respective app developers.
  12. JoseGarciaPM
    Cupcake Sep 4, 2019
    JoseGarciaPM , Sep 4, 2019 :
    It works 100% both by Bluetooth and cable now.
    Switch pro is still laggy
  13. Parth0085
    Eclair Sep 4, 2019
    Parth0085 , Sep 4, 2019 :
    task manager doesn't work smoothly.
    I had to kill the app to stretching upwards the screen.
    almost another system work proper.
    Awesome Work one➕7️⃣
    Android 10 another love.[e]1f60d[/e]
  14. gustavofrezza
    Eclair Sep 4, 2019
    gustavofrezza , Sep 4, 2019 :
    Doesn't wiped... I just done a dirty flash by updater (not twrp) and works like a charm!
    My previous version was DP5.
  15. Parth0085
    Eclair Sep 4, 2019
    nop bro
    no tiny data was wiped!!
  16. pratzzz
    Froyo Sep 4, 2019
    pratzzz , Sep 4, 2019 :
    Just do one thing, boot the twrp from fastboot and then flash magisk, using fastboot you will be able to see the internal storage and no data will be erased.
    Parth0085 likes this.
  17. Parth0085
    Eclair Sep 4, 2019
    Lahiru Rashinda likes this.
  18. chrisdarnel
    Cupcake Sep 4, 2019
    when trying to boot twrp via fastboot it stays on the OP+ logo and Fastboot under it. never boots into twrp.
    fcarmona likes this.
  19. superplus
    English POC Assistant Head Moderator Sep 4, 2019
    superplus , Sep 4, 2019 :
    Hi, please don't post about other devices, this thread is for the OP7 Series. Also, please have a look at the Terms & Rules (https://forums.oneplus.com/help/terms), in addition to being off-topic here (Rule 1.3), there is never any point to asking about updates in general. No one knows when they will arrive, no ETAs are ever given, best is to keep an eye on your device's subforums (https://forums.oneplus.com/forums/OnePlus6-6T/ in this case), since an update will always be accompanied by an official announcement thread (like this one).
    mycatisajoker and Petzkub like this.
  20. Sumedh_Nadgir
    Froyo Sep 4, 2019
    Sumedh_Nadgir , Sep 4, 2019 :
    Installed the beta on the OP7 just now.
    1) I notice right away is its difficult to swipe the recent apps away. Please make it easier to swipe recent apps away.
    2) Slight lag in call receiving call animation
    3) *Question* Why do I see 2 Google pay app. one native and one from app Store. I'm from India.
