192
Oxygen OS Open Beta 1 for the OnePlus 7T and OnePlus 7T Pro
  1. bprrkl
    Gingerbread Mar 16, 2020
    Kshitij3687 likes this.
  2. Chirag_Gohil
    Honeycomb Mar 16, 2020
    Chirag_Gohil , via OnePlus 7T , Mar 16, 2020 :
    did you lost anything? i means one plus icons apps which was inbuilt in the oxygen OS and others one plus apps! community apps, weather apps etc
  3. R_Akash_Aku
    Donut Mar 16, 2020
  4. renz2ho
    Froyo Mar 16, 2020
    renz2ho , Mar 16, 2020 :
    yes all you hear in the speaker from the device it show caption.
  5. hamvaspeter
    Eclair Mar 16, 2020
  6. renz2ho
    Froyo Mar 16, 2020
    i think no.. but the problem only some program not work properly. Or you should go install again the correct firmware.
    hamvaspeter likes this.
  7. renz2ho
    Froyo Mar 16, 2020
    im still observing. but i noticed its looks like not cosuming battery this beta version?
  8. hamvaspeter
    Eclair Mar 16, 2020
    hamvaspeter , via OnePlus 7T Pro , Mar 16, 2020 :
    Do I have to flash the linked ROM, or do I have to use the unbrick tool by XDA? are the downgrade links korrekt?
  9. renz2ho
    Froyo Mar 16, 2020
    just download only the rom which same with your phone model in the first page and then put the file you downloaded in the phone storage and install it via local upgrade.
  10. RohanHanok067
    RohanHanok067 , via OnePlus 7T Pro , Mar 16, 2020 :
    I felt like its taking more time to complete 100% charge
  11. renz2ho
    Froyo Mar 16, 2020
    maybe later i will check . because my phone still 47%
    Anyway which phone you got? because i have only 1+7t model. Did you you try to disabled optimize battery charging so you will know it.
  12. Sunny4415
    Eclair Mar 16, 2020
    Sunny4415 , via OnePlus 7T , Mar 16, 2020 :
    Hello Team,
    I have successfully installed the open beta ROM for my one plus 7T.
    But when I tried to revert back to the stable version, I am getting the following error.
    Could anyone please help me.
  13. RohanHanok067
    7t pro
    it's by default on
    so no need if changing
  14. renz2ho
    Froyo Mar 16, 2020
    yes its right.
  15. J1577447941899
    Cupcake Mar 16, 2020
  16. renz2ho
    Froyo Mar 16, 2020
    I just want to inform Navigation gesture bottom bar it's gone in homescreen before if you touch they will showed bar in the bottom. I dont know? i hate only they have more space in the bottom.
  17. Z1573828598844
    Froyo Mar 16, 2020
    Z1573828598844 , Mar 16, 2020 :
    no, all ok and perfect
  18. renz2ho
    Froyo Mar 16, 2020
    Hi.. mine i dont have error like that maybe you should repeat to download the file maybe its corrupted. Try to open the file to make it sure its not corrupted. Remember back up your file first before you install the stable firmware.
  19. renz2ho
    Froyo Mar 16, 2020
