192
Oxygen OS Open Beta 1 for the OnePlus 7T and OnePlus 7T Pro
  1. Sunny4415
    Eclair Mar 16, 2020
    Sunny4415 , via OnePlus 7T , Mar 16, 2020 :
    Hello Bro,
    Can you please send me the link to the MP FILE rom for one plus 7T india(stable)
  2. renz2ho
    Froyo Mar 16, 2020
    renz2ho , Mar 16, 2020 :
    It's on the first page bro..Wait, Did you try already to open or check the file via zip?
  3. renz2ho
    Froyo Mar 16, 2020
    I just want you to know that i have EU variant.. maybe we are not the same file size of Stable firmware. So it's better to check or open the file to make it sure not corrupted. And if still error happen try download the file again.
  4. karan prasaad
    Cupcake Mar 16, 2020
  5. guruprasaddp
    Froyo Mar 16, 2020
  6. guruprasaddp
    Froyo Mar 16, 2020
  7. Richca
    Froyo Mar 16, 2020
    Richca , via OnePlus 7T , Mar 16, 2020 :
    from what I can see I've only lost the OnePlus oxygen icon pack, the weather, community app still there, so far so good
  8. karan prasaad
  9. TheBlitz7
    The Lab Reviewer - OnePlus 9 Series Mar 16, 2020
    TheBlitz7 , Mar 16, 2020 :
    The use of both the single and double tap for the Ambient Display and lockscreen is great!
  10. bprrkl
    Gingerbread Mar 16, 2020
    bprrkl , via OnePlus 7T , Mar 16, 2020 :
    move the file from downloads to root folder and remove the .jar extension and then go to software update and select local update u shd be able to see it. I believe the file u downloaded should be in download folder.
    karan prasaad likes this.
  11. hitesh5209
    hitesh5209 , via OnePlus 7T Pro , Mar 16, 2020 :
    i downloaded the full rom from official oneplus site and copied it phone storage it show zip.jar file
    and it can't show in system updates-local upgrades
    how i install tha update
  12. Chirag_Gohil
    Honeycomb Mar 16, 2020
    Chirag_Gohil , via OnePlus 7T , Mar 16, 2020 :
    only beta1 install?? did you go back stable version MP??
  13. Djfox123
    Donut Mar 16, 2020
  14. Richca
    Froyo Mar 16, 2020
  15. Chirag_Gohil
  16. Richca
    Froyo Mar 16, 2020
  17. Prasanna009
    Froyo Mar 16, 2020
  18. ARIJIT1+8PRO
    ARIJIT1+8PRO , via OnePlus 7T , Mar 16, 2020 :
    Just rename the file extension from zip.jar to only .zip. thats it.it works.
    hitesh5209 likes this.
