337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. Staf Heymans
    Froyo Sep 21, 2019
  2. A1560648267550
    Gingerbread Sep 21, 2019
  3. Swejuggalo
    KitKat Sep 21, 2019
    Swejuggalo , Sep 21, 2019 :
    Then Android 10 is out for your device. Want stable or beta?
    You can update with Oxygen Updater to both Beta or Stable if you like.
    How to update with Oxygen Updater.
    Oneplus warns about using it so be warned. Use at your own risk. Possible issues that I can think of. International users can get US specific updates (that you don't need and should not use) for example. It only knows International and EU not special regions within those regions.
    All it really does is to help with downloading the file for you. With the correct name and correct directory (no zip.jar or anything). All you need to do is to install it when downloaded by the normal local install.
    Users without root normally only need full update when changing from 9 to 10.
    Select what path you want to be on. Stable or Open beta. http://bit.ly/2HTDBRY
  4. Swejuggalo
    KitKat Sep 21, 2019
  5. Staf Heymans
    Froyo Sep 21, 2019
    Staf Heymans , Sep 21, 2019 :
    yes and stable is a few days from now so he doesn't need to wait long
  6. D1561724855045
    Cupcake Sep 21, 2019
  7. D1561724855045
  8. Swejuggalo
    KitKat Sep 21, 2019
    Stable is out on 7 AA builds already
  9. Staf Heymans
    Froyo Sep 21, 2019
  10. ashokreddy_99
  11. Staf Heymans
    Froyo Sep 21, 2019
    yes and sometimes it does not show at all
  12. Guddu_009
    Guddu_009 , Sep 21, 2019 :
    Hi Everyone,
    I am using OnePlus 7 Pro and currently running Android 10 Beta 2 . I just curious to know whether I need to downgrade my device to Android 9 to receive the stable Android 10 Update or will I get it via the OTA. Help!
  13. docnok63
    Jelly Bean Sep 21, 2019
    docnok63 , Sep 21, 2019 :
    First post has your answer
  14. Z1564815473473
    Donut Sep 21, 2019
    Z1564815473473 , Sep 21, 2019 :
    After updation of new version beta facing blue tooth notification problem as well as well volume of phone is getting effected means volume is become low as compare to before pls improve it or pls suggest me same ....
  15. S1564465260207
  16. J1545626404393
    Donut Sep 21, 2019
    J1545626404393 , Sep 21, 2019 :
    guys oxygen updater shows update but system update can't show.is this update stable or not.i am bit confued.wat I do...help me..
  17. Prateek00l
    Froyo Sep 21, 2019
    Prateek00l , Sep 21, 2019 :
    Yes Please
  18. S1564465260207
    S1564465260207 , Sep 21, 2019 :
    This stable update has some bugs in it too.
  19. I1517067053377
    Eclair Sep 21, 2019
    I1517067053377 , Sep 21, 2019 :
    whats app notification setting crashed while changing notification sound.please see the attached screen shot. i think its a bug.
    SaulVázquez95 likes this.
  20. RakeshJha18
