337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. G1565150989840
    Eclair Sep 21, 2019
    G1565150989840 , Sep 21, 2019 :
    ok
  2. Georgeoneplus7pro
    Ice Cream Sandwich Sep 21, 2019
  3. D1560965181344
    Gingerbread Sep 21, 2019
    D1560965181344 , Sep 21, 2019 :
    VPN doesn't work...but curious as to where you're located George? Good to see successful downloads anyways. Enjoy and let us know your issues of course. We're in this together!
    X1569112819018 likes this.
  4. Georgeoneplus7pro
    Georgeoneplus7pro , Sep 21, 2019 :
    I am very dissapointed. All the problems in DP4, DP5, Beta1 and 2 gathered and brought on this 10 slable. I downloaded the rum with the application Oxygen Updater. I'm in Europe.
  5. the_golub89
    Cupcake Sep 21, 2019
    the_golub89 , Sep 21, 2019 :
    I CAN'T BELIEVE THAT STILL IN ANDROID 10,YOU DIDN'T FIX THE PROBLEM WITH NOTIFICATION HORIZON LIGHT!IT STILL LIGHTS ONLY ONCE...OMG...IS IT SO DIFFICULT TO MANAGE FOR USERS A TIME FRAME IN SECONDS FOR HOW LONG IT WILL LIGHT?!?THIS IS SO FRUSTRATING...
  6. O1568113000158
    Eclair Sep 21, 2019
  7. arjunan2609
    Eclair Sep 21, 2019
    arjunan2609 , Sep 21, 2019 :
    recently updated Android Q beta version,but I can't find notch turn on/off.Any idea where to find it..
  8. RAJAN RAJU
    Donut Sep 21, 2019
    RAJAN RAJU , Sep 21, 2019 :
    did not receive Android 10 update for my one plus 7 pro
    please tell the process of updating stable version
  9. PastorBri
    PastorBri , Sep 21, 2019 :
    Gestures seem to freeze and fail to work at times on Beta 2. Auto brightness get really dark at times need to turn off auto brightness.
  10. L1560881506911
    L1560881506911 , Sep 21, 2019 :
    where are the notifications icons? they don't show in the status bar !!!!
    for example, I wasn't seeing the location icons when open maps or incognito mode when I open chrome
    avdin likes this.
  11. PastorBri
    They are on mine...try rebooting
  12. L1560881506911
  13. PastorBri
    What do I need to Mark as important, my question?
  14. itisdenis
    itisdenis , Sep 21, 2019 :
    So my question is why there is no rounded corners in "Vibration" mode on Alert Slider and is this a feature or the bug that in some applications status bar just hidden on OnePlus 7? Maybe make this happen optional?
  15. itisdenis
    Wow! It was surprise for me that screenshots was taken with info in status bar, while I can't see this in normal use.
  16. M1567959271291
    Eclair Sep 22, 2019
    M1567959271291 , Sep 22, 2019 :
    hola en la pagina oficial de oneplus esta para descargar la version estable de antes de la beta del 10. osea la 9.5.11 del 3 de agosto del 2019 por si quieres volver a ella te dejo aqui el link para el 7pro
    https://www.oneplus.com/es/support/softwareupgrade/details?code=11
  17. SaulVázquez95
    Donut Sep 22, 2019
    SaulVázquez95 , Sep 22, 2019 :
    Mil gracias compañero. Esa ya la tenía fichada. Yo he vuelto a la 9.5.4 y sinceramente, lo mejor que hay en batería.
    Encontré un post en XDA, y utilizando un programa en el Pc (como si tuvieras un brick en el tlf) te pones esa versión y un lujo. Eso sí, antes tuve que instalar el RollBack de Android 10 a Android 9 y luego procedí a abrir el bootloader. Usé el programa y te pone esta versión y te cierra el bootloader. Me salta la .11 para actualizar por OTA pero voy a pasar un poco de ella.
    Y respecto a Android 10 ... La estable no es tan estable. Está basada en la Beta y malamente. El Horizon Light no funciona y tiene bugs de las betas. Diría, a voz de pronto, que nos usan de conejos de Indias para catar Oxygen 10 para los nuevos terminales y pulir antes los bugs en la "estable".
  18. D1560965181344
    Gingerbread Sep 22, 2019
  19. M1567959271291
    Eclair Sep 22, 2019
    nose como hacer para volver a la version anterior . He ido a lo de mejora local pero solo me aparece la version beta la nueva que descargue no
  20. SaulVázquez95
    Donut Sep 22, 2019
    Es mejor que la descargues desde un Pc y lo hagas desde allí. Además, te borrará todo lo del terminal.
    Y tienes que instalar primero el RollBack, no la .11, si no brickeas el tlf.
