337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. Ryan_McConville
    Donut Sep 23, 2019
    Ryan_McConville , Sep 23, 2019 :
    I've downloaded the correct file. Where do I put the file now? Thanks for the help.
  2. Swejuggalo
    Lollipop Sep 23, 2019
    Swejuggalo , Sep 23, 2019 :
    Directly under root dir/main storage/local storage or what ever the file explorer calls it. Make sure it is called zip and only that. If it has jar in the end remove it.
    Ryan_McConville likes this.
  3. Amogh46
    Cupcake Sep 23, 2019
    Amogh46 , Sep 23, 2019 :
    Is there any tentative timeline available for Open Beta updates?
    Will the beta users get the security updates monthly?
  4. CharanD1
  5. stevevue
    Eclair Sep 23, 2019
    stevevue , Sep 23, 2019 :
    unacceptable!!! what's going on?? it's getting worse and worse for me [e]1f614[/e]
  6. stevevue
    Eclair Sep 23, 2019
    same thing for me now for the last month and half, battery has been getting worse, today is the worst I've seen it perform forsure
  7. Nic2112
    Ice Cream Sandwich Sep 23, 2019
  8. stevevue
    Eclair Sep 23, 2019
    I'm not sure what you're referring to, but my phone's software has the latest updates, for tmobile
  9. C1566492973084
    Gingerbread Sep 23, 2019
    C1566492973084 , Sep 23, 2019 :
    my only camera complaint with Beta 2 is the video camera software. would like 3 cameras with 4k60FPS. other than that not to shabby.
    EDIT- this app really compresses the images. [e]1f61e[/e]
  10. AzuLa9713
    Honeycomb Sep 24, 2019
    AzuLa9713 , Sep 24, 2019 :
    then why comment on beta forum?
  11. stevevue
    Eclair Sep 24, 2019
    stevevue , Sep 24, 2019 :
    because I'd like to see battery improvement, narc
  12. AzuLa9713
    this is for beta users. commenting here won't improve your battery. if you comment may be on t mobile related forum, u might actually get some help.
  13. Muhammed Afeef M
    Froyo Sep 24, 2019
  14. amol1223
    Eclair Sep 24, 2019
    amol1223 , Sep 24, 2019 :
    I'm bored seeing this screen again and again. When is Android 10 coming? Month end means exactly 30 Sept?
  15. ashjain90
    Cupcake Sep 24, 2019
  16. G_Rishabh_Srivastava_jRl
    Eclair Sep 24, 2019
    H1509642441700 likes this.
  17. Foxfire_dome
    Foxfire_dome , Sep 24, 2019 :
    I have been using banking apps since the start of the beta 2 and all are working fine, ICICI and PNB are working smoothly no issues seen there and other UPI apps are working great too!!
  18. Foxfire_dome
    Since the beta 2 update I haven't seen any issues while calling or receiving a call, most of the issues have been solved.
  19. X1569226814584
    X1569226814584 , Sep 24, 2019 :
    Beta 1 was working fine. after updated to beta 2 battery draining fast. 30 to 40 % loss of uptime. please consider this also.
  20. X1569226814584
