337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. G_Rishabh_Srivastava_jRl
    Eclair Sep 24, 2019
    G_Rishabh_Srivastava_jRl , Sep 24, 2019 :
    Have you applied the forced dark mode from Developer options ? or the normal dark from Customisations menu ?
  2. Foxfire_dome
    Cupcake Sep 24, 2019
    Foxfire_dome , Sep 24, 2019 :
    yup I tried it on both ICICI BANKING APP WORKS FINE WITH NO ISSUES EVEN IF YOU LOGIN WITH FINGER PRINT
  3. G_Rishabh_Srivastava_jRl
    Eclair Sep 24, 2019
    Not the banking apps. I was asking about the calling screen. The icons of mute, call recording etc. are missing when I apply the system wide dark mode from Developer options.
  4. Foxfire_dome
    No bro, it's not the icons issue, the icons are forced to turn black as well that's why you aren't able to see it.... report an issue if you want....
    these two shows the incoming call where the icons are not showing because they are black and the background is black as well
    these two are dialled calls where you can see the black icons because of a lil bit of lighter background
    VaibhavBhargava likes this.
  5. VaibhavBhargava
    Lollipop Sep 24, 2019
    VaibhavBhargava , Sep 24, 2019 :
    There is a good reason that option is still in Developer options. As it indiscriminately applies dark mode to everything. (See WhatsApp for example, it looks ugly). It is not smart enough and therefore it should not be used.
  6. G_Rishabh_Srivastava_jRl
    Eclair Sep 24, 2019
    Understood. Thanks :)
    Is there any way to exclude certain apps from the Force Dark mode ?
  7. Foxfire_dome
    The location permission is set to mandatory for the contacts app in the beta 2, and if the permissions are not fulfilled then the app won't open.
  8. Foxfire_dome
    For now there is no way in beta 2 update to exclude app from force dark mode not even in the developer options.
  9. VaibhavBhargava
  10. Foxfire_dome
    Ryan_McConville
    I have the beta installed from the oxygen updater app but I can't update to oxygen ten. I did a factory reset and it's still on the 2nd beta. can anyone help?​
    You have to download the update file of android 10( EU and International versions available) then upgrade it using local update(full data wipe) OR if you want to downgrade to android pie you need to do a full flash which will wipe all your data.
  11. H1509642441700
    H1509642441700 , Sep 24, 2019 :
    after install ob 2 in oneplus 7 jio tv application getting crash...not opening atall...pls look in this
  12. Raghaw_D
    Eclair Sep 24, 2019
  13. Swejuggalo
    KitKat Sep 24, 2019
    Swejuggalo , Sep 24, 2019 :
    Reinstalled the app and it did not help? It might be need a update to support 10.
    You could use the community app feedback tool and report this.
  14. Swejuggalo
    KitKat Sep 24, 2019
    Check here
    Raghaw_D likes this.
  15. Raghaw_D
    Eclair Sep 24, 2019
  16. H1509642441700
    s i am also facing same
  17. Swejuggalo
    KitKat Sep 24, 2019
    There is also a forced dark mode in developer options. But that is buggy and is not adviced to use if you ask me. Better to wait for native dark mode support in the apps.
  18. Raghaw_D
    Eclair Sep 24, 2019
    Raghaw_D , Sep 24, 2019 :
    I would like to wait for some time for the stable version.
    Thank you for your advice [e]1f44d[/e] I appreciate it.
  19. Swejuggalo
    KitKat Sep 24, 2019
    Using nuanced dark mode and then forced dark mode and even the apps own dark mode.. Too much darkness if you ask me. Does not work well together
  20. Raghaw_D
    Eclair Sep 24, 2019
    Why only Axis Bank app is facing this issue, while all other banking applications are working fine?
