337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. Swejuggalo
    Lollipop Sep 24, 2019
    Swejuggalo , Sep 24, 2019 :
    Rollback or directly to 10...
    My forum post with download links to upgrade to 10 http://bit.ly/2NqjbUR
  2. G_Joe_Kelly_hgoD
    Eclair Sep 24, 2019
    G_Joe_Kelly_hgoD , Sep 24, 2019 :
    Hi! I want to leave the beta and go back to stable but the link one these forums dont seem to work
  3. Swejuggalo
    Both rollback and stable flash of 10 over beta wipes the phone. If the backup only exist on the phone and has not been stored online or on USB drive it is gone
  4. Swejuggalo
    What happens? You need to download the file and flash the same way as when you joined beta
  5. G_Joe_Kelly_hgoD
    Eclair Sep 24, 2019
    Yeah I get that. I just can't seem to find the 9.0 file
  6. S1563688487224
    Cupcake Sep 24, 2019
    S1563688487224 , Sep 24, 2019 :
    i did go settings back up option along with system/backup/ google drive is on
  7. Swejuggalo
    Well... You can flash 10 directly. 9 rollback is in the link I posted too. Both methods will wipe
  8. Swejuggalo
    How did you do the backup then? Oneplus Switch?
  9. S1563688487224
    no i am already oneplus 7 pro user so not thru switch .Do i have to?
    i went setting/ back up
  10. Swejuggalo
    Read what the backup really stores. It's not everything. In Oneplus Switch you can save all pictures and stuff too. Just store that backup somewhere the next time you need it.
  11. S1563688487224
    omg i see so where do i really have to back up
  12. Swejuggalo
    This stores all your pictures and stuff too. Copy the folder opbackup somewhere next time.
    S1563688487224 likes this.
  13. F1567609542484
    F1567609542484 , Sep 24, 2019 :
    I'm sure it's been asked already but I'm a noob of OnePlus. if I stay on the beta release, will I keep getting beta ota before they rollout stable? is there any significant difference between ob2 and stable 10? thanks
  14. FilippoNespolo
    FilippoNespolo , Sep 24, 2019 :
    One issue: when i try to open any kind of games the display goes off and only pushing any times the Power Botton all the system restart. This problem started with this second release of beta
  15. Swejuggalo
    Betas will get beta 3, 4, 5 and so on. But never Stable unless manually changing by installing stable 10 over beta (thus wiping storage).
    Stable is somewhere near beta 1/2. Not much (if any) benefit of changing to stable currently.
    If beta is stable enough for you stick with it. It does not really get better at stable. Atleast not now it seems.
    F1567609542484 likes this.
  16. ronnyhawks
    Ice Cream Sandwich Sep 24, 2019
    ronnyhawks , Sep 24, 2019 :
    not sure if anybody has figured this out yet or not, but Nova Launcher and the full screen gestures (swiping up to go back on left or right of screen) work just fine. I have 0 issues on Beta 2
  17. ABala
    Eclair Sep 24, 2019
    ABala , Sep 24, 2019 :
    would it stick after a restart?
  18. ronnyhawks
    I can confirm that it does stick after a restart [e]1f44d[/e]
  19. ronnyhawks
    I should also state that I have Nova Launcher Beta and Nova Prime as well. Nova Prime doesn't disappear from the app drawer, but I can confirm that it does work, and all full screen gestures are working perfectly fine, even after a reboot
    ABala likes this.
  20. G_Basava_Manju_qVWb
    Cupcake Sep 25, 2019
