337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. Swejuggalo
    Lollipop Sep 25, 2019
  2. AzuLa9713
    Honeycomb Sep 25, 2019
    AzuLa9713 , Sep 25, 2019 :
    can confirm this..
  3. H1511408753784
    Cupcake Sep 25, 2019
  4. DhruvPatel17
    Donut Sep 25, 2019
  5. S1563882174725
    S1563882174725 , Sep 25, 2019 :
    i am facing some issues like when connected to wired earphones the incoming calls disconnected automatically, sometimes the phone restarts automatically.
  6. H1560616248151
  7. Arun Kumar Polu
    Eclair Sep 25, 2019
  8. R1558207853582
  9. Georgeoneplus7pro
    Jelly Bean Sep 25, 2019
    Georgeoneplus7pro , Sep 25, 2019 :
    The GPS function should be optimized, report the problem, you send them a feedback.
  10. F1561950538456
  11. F1561950538456
  12. SgN_Juanlu , via OnePlus 7 Pro Nebula Blue , Sep 25, 2019 :
    Flashed on OP7Pro (Clean flashed), everything seems to be fine except:
    - Automatic brightness is still working "strange", it needs to be a bit tight.
    - It's missing pocket mode (It can be solved by custom Kernel, but users prefer an option in the ROM)
    - Battery drain when the display is on is very high, the system can be optimized many more (idle drain is fine)
    - It's missing always on display (Personally i don't care about it, but many users want it)
    - It's missing an option to have fingerprint always enabled included when the display is off. I know that it's possible to hide the "image" of the fingerprint and keep it active when the display is off
    - The system is not as smooth as how it must be (90Hz forced with adb)
    - There's a delay with the WiFi, it takes too much time to search the networks, and it doesn't auto connect to a better WiFi automatically, we need to tap it manually.
    - I miss notification icons with colours, when we tap the status bar it shows the colours of the icons, i think that users will like it, an option to enable or disable that colours, it's easy to add in the code. (Attached image)
    That's all for the moment, keep up the good work!
    docnok63, davidjuarezalc and Covrivov like this.
  13. Georgeoneplus7pro
    SgN_Juanlu likes this.
  14. C1566492973084
    Gingerbread Sep 25, 2019
    C1566492973084 , Sep 25, 2019 :
    Another Reason Transparent bottom bar would be better than this multi colored black or white one. mismatch even with nuasance dark mode turned on 1569420202462.jpg
    Xcutioner likes this.
  15. Xcutioner
    ronnyhawks likes this.
  16. Xcutioner
    Xcutioner , Sep 25, 2019 :
    Yea OOS navbar doesn't turn dark most of the time when it needs to, which can get very annoying (the reason why I tend to hide it)
  17. Xcutioner
    That Screenshot hurts my eyes..... I wanna find where you live and disable that navbar for you now....
    K1537551812387 likes this.
  18. Raghaw_D
    Eclair Sep 25, 2019
    Raghaw_D , via OnePlus 7 Pro , Sep 25, 2019 :
    After updating my OP7Pro to Android 10, the battery is draining so fast. Although I applied the Nuanced Dark theme the screen is consuming 38% battery and after that android system is consuming 19% battery.
    Does anyone notice the same thing yet?
  19. vihangbhatt27
    Donut Sep 25, 2019
  20. vihangbhatt27
    Donut Sep 25, 2019
