337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. N.Prakash
    Cupcake Sep 26, 2019
    N.Prakash , via OnePlus 7 , Sep 26, 2019 :
    download the file in other device and then copy to root storage as this same happen with me also
  2. W1565031392487
  3. Raghaw_D
    Eclair Sep 26, 2019
    Raghaw_D , via OnePlus 7 Pro , Sep 26, 2019 :
    I too faced, but different thing regarding the phone call. While talking with someone on a speaker, I noticed that the overall volume is low as before upgrading.
    Does anyone else feel the same?
  4. kramik
    Donut Sep 26, 2019
    kramik , Sep 26, 2019 :
    Hello Fellows.
    The horizon Light does not work with all notifications, only works with SMS notifications.
    Is it only in mine or all with OP 7 Pro and OB 2?
  5. Z1564768169287
    Donut Sep 26, 2019
  6. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Sep 26, 2019 :
    I haven't used it much. But when I did it seems to function as intended (the community app triggers it perfectly fine).
    It's lacking functions that makes it really useful according to me... Repeating pattern for missed notifications is a bare minimum.
  7. MarcoFerri
    MarcoFerri , Sep 26, 2019 :
    Poket mode is very much needed
  8. Nic2112
    Ice Cream Sandwich Sep 26, 2019
    Nic2112 , via OnePlus 7 Pro , Sep 26, 2019 :
    you have to edit the notification settings of each app and make sure you enable that notification.
    docnok63 likes this.
  9. Foxfire_dome
    Foxfire_dome , Sep 26, 2019 :
    the Axis bank app is not made to support android 10 beta. a new update will be released by the bank soon.
  10. MaximusTej
  11. lyricalsaint316
    Gingerbread Sep 26, 2019
  12. RS31
    RS31 , Sep 26, 2019 :
    when will be the official android 10 update for OnePlus 7 pro is coming???
  13. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Sep 26, 2019 :
    It's already out. Flash Stable manually over beta yourself. You will not get the stable otherwise. Beta gets beta updates. Manually installing stable over beta wipes the phone. Scroll up and you see links to full downloads and stuff
  14. V1569217662330
  15. G_Blaze_VaEm
    G_Blaze_VaEm , Sep 26, 2019 :
    don't know why but my alert slider is not working properly,when I switch from normal to silent it's works but while switching back to normal it's stucks at vibration so I need to restart my phone to make it normal profile again.can someone knows to fix this??
  16. 1207120
  17. Cervantes
    Lollipop Moderator Sep 26, 2019
    Cervantes , Sep 26, 2019 :
    Hi
    Please You read the first post
    The beta or update thread is a thread of questions and/or commentary
    Thread merged
  18. The_Rock90
    Jelly Bean Sep 26, 2019
    The_Rock90 , Sep 26, 2019 :
    Need something different with UI in software update. I am bored of this. Using same UI since 5 years
  19. DragonsSense
    Eclair Sep 26, 2019
    DragonsSense , Sep 26, 2019 :
    You do have the option of using a new launcher. The point of this launcher is debloated and simplistic.
  20. F1569521380599
