337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. L1569685261733
    Cupcake Sep 28, 2019
  2. Swejuggalo
    Lollipop Sep 28, 2019
    Swejuggalo , Sep 28, 2019 :
    Are you on the beta? If yes you need to download stable 10 and flash it over the beta. It will wipe the phone though. Beta always updates to new betas.
    My forum post with download links to the 10 upgrade and 9 downgrades.
    https://forums.oneplus.com/threads/...-and-oneplus-7.1105492/page-118#post-20784258
    Short link if link above is broken: http://bit.ly/2NqjbUR
  3. D1564998114935
    D1564998114935 , Sep 28, 2019 :
    i have issues with the screen turning full black when opening some apps.
    Going back to home doesnt work either, it needs a forced reboot
    Apps like Youtube and Simdashboard and CSR2 have done this for me.
    This was in beta 1 and beta2!
    If home does work and i reopen the app from the list where runnings apps are. Then it does work... hmm
    Anyone else that has it?
  4. The_Rock90
    Jelly Bean Sep 28, 2019
  5. bpwest80 , via OnePlus 7 Pro Nebula Blue , Sep 29, 2019 :
    Anyone else having an issue with Google Duo? The app works but the person I'm talking to can't hear a word I'm saying. I've tested it myself and even though I'm talking, there's only silence on the other end of the line.
  6. 笑对人生
    Cupcake Sep 29, 2019
  7. Max_Fremps
    Gingerbread Sep 29, 2019
    Max_Fremps , Sep 29, 2019 :
    hi guus, i'm on stable Android 10 for op7pro but i want ti switch on beta (beta 2 of Android 10) what i need to do this?
    i'm full stock
  8. Ven96
    Froyo Sep 29, 2019
    Ven96 , Sep 29, 2019 :
    Please don't. It's the same thing.
  9. VaibhavBhargava
    Lollipop Sep 29, 2019
    VaibhavBhargava , Sep 29, 2019 :
    As of now they have the same features, but this build is updated more frequently for development and testing purposes. Sometimes some features or apps may not work.
    So please do so at your own risk
    Don't forget to read the first post before downloading from the link and keep your important data backed just in case.
    https://oxygenos.oneplus.net/OnePlus7Oxygen_13.W.10_OTA_010_all_1909112326_194926fb85614c0b.zip
    Once the file is downloaded into your device, move it outside of the downloads folder into the main/root directory. The update should be visible under Local Update in System Update's settings.
  10. Dmytro Semenchuk
    Y1517128233892 likes this.
  11. VAMPIRE2510
  12. W1569736264520
  13. W1569736264520
  14. Swejuggalo
    Swejuggalo , Sep 29, 2019 :
    Depends if you feel like beta is something you will continue with.
    Right now OB2 is more or less identical to stable 10. Later on beta might offer extra features but also possible issues. Whenever you do the jump a link to the download should be in the first post (directly to the Oneplus homepage). OB3 is not far away.
    the_reckoner likes this.
  15. Swejuggalo
    Link to a post that might help you.
    Direct link but often broken in community app: https://forums.oneplus.com/threads/...-and-oneplus-7.1105492/page-282#post-20798757
    Short link since community app does not like the link above: http://bit.ly/2kZzs6x
  16. K1568883116990
    K1568883116990 , Sep 29, 2019 :
    The nightscape is really really messed up, the photos i took at night looks like a crayon drawing. Anyone else facing this issue?
    This problem is also occurring on night sight on the gcam mod
    the_reckoner and Covrivov like this.
  17. Covrivov
    Covrivov , via OnePlus 7 Pro Nebula Blue , Sep 29, 2019 :
    Confirm. On oos camera, looks like the photos are never in focus.
    the_reckoner and K1568883116990 like this.
  18. K1568883116990
    yeah, the cameras were fine on Android 9, it probably looks like a beta bug
    Covrivov likes this.
  19. Y1566448767553
    Donut Sep 29, 2019
  20. G_Toni_Jerković_uDrY
    Froyo Sep 29, 2019
    G_Toni_Jerković_uDrY , Sep 29, 2019 :
    i apologize if this has been asked and answered but if anyone switched from this beta to stable are there any differencies or is the exact same thing?
    thanks
