337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. C1566492973084
    Gingerbread Oct 4, 2019
    C1566492973084 , Oct 4, 2019 :
    definitely hoping that OnePlus includes a set time feature for dark mode or toggle on quick settings in the beta 3
    clarkgable and docnok63 like this.
  2. U1570138479019
    Cupcake Oct 4, 2019
    U1570138479019 , Oct 4, 2019 :
    nhi ho rha hai
  3. docnok63
    Jelly Bean Oct 4, 2019
    docnok63 , Oct 4, 2019 :
    That's fine. I've never seen OnePlus put GMS in their changelog, the security patch date is old, and it fails signature validation. It's obviously not a authentic OP file, I just wanted to mess with it a bit. You keep it.
  4. U1570138479019
    Cupcake Oct 4, 2019
  5. dadoc04
    Honeycomb Oct 4, 2019
    dadoc04 , Oct 4, 2019 :
    Thanks man ...i do use migrate and twrp, however migrate isn't working with Q from what i gather so i was trying to find an alternative since i want to clean flash
    Thanks so much for replying.
  6. docnok63
    Actually I discovered Migrate while on 10 and did my first backup with it on 10 ignoring all the warnings in the app saying it's only been tested or whatever up to 9. I then completely wiped my phone via TWRP including format data, and flashed 9.5.11. Once booted, I skipped all setup options, rooted, restored my Migrate backup in TWRP then the app, and profit. It was quite smooth.
    dadoc04 likes this.
  7. Raghaw_D
    Eclair Oct 4, 2019
    benny3 likes this.
  8. U1570138479019
    Cupcake Oct 4, 2019
  9. Swejuggalo
    KitKat Oct 4, 2019
    Swejuggalo , Oct 4, 2019 :
    What version are you on and what phone?
    Want 10?
    Try full updates instead.
    Link to a post that might help you.
    Direct link but often broken in community app: https://forums.oneplus.com/threads/...-and-oneplus-7.1105492/page-282#post-20798757
    Short link since community app does not like the link above: http://bit.ly/2kZzs6x
    If all links is broken open then with a mobile browser.
  10. G_Aniket_Gaikwad_jPRQ
    Cupcake Oct 4, 2019
    G_Aniket_Gaikwad_jPRQ , Oct 4, 2019 :
    so we can say that, Sept security update will come along OS10[e]1f603[/e]
  11. docnok63
    Yes, it's in all three builds of A10 (OB1, OB2, and unStable.) Official October patch has not been released by Google yet, so it can not be in an OP build until after that happens (historically, not later than the 7th.)
  12. X1569774348033
    Cupcake Oct 4, 2019
    X1569774348033 , Oct 4, 2019 :
    Hi. I want to remove beta update of andriod 10 from my one plus 7. Please help
  13. docnok63
    People worry about these security patches too much. My NVIDIA SHIELD was updated just a couple of days ago and it didn't include an update to Sept. patch level. It's still on July. You know what happened to my device? Nothing. It still turns on. It still streams things just fine.
    Are you trying to go to A10 or roll back to A9?
    DeathMoJo likes this.
  14. X1569774348033
    Cupcake Oct 4, 2019
    Going back to andriod 9
  15. docnok63
    You phone will be wiped. Make a backup and offload to PC or cloud before rolling back...
    Want to go back to Android Pie? Download the Rollback package from the links below:
  16. X1569774348033
    Cupcake Oct 4, 2019
  17. X1569774348033
    Cupcake Oct 4, 2019
    No use. I downloaded it. Even renamed removing .jar from end. No use
    vasam chaitanya kumar likes this.
  18. Swejuggalo
    KitKat Oct 4, 2019
    What happens? Screenshot of the problem perhaps
  19. X1569774348033
    Cupcake Oct 4, 2019
    i downloaded oneplus 7 downgrade file. copy pasted it in my internal phone. and then system updates. i could not find the copy in local folder
  20. Swejuggalo
    KitKat Oct 4, 2019
    If it's jar don't just remove it. Also make sure it ends with .zip
    X1569774348033 likes this.
