337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. rema5
    Donut Oct 12, 2019
    rema5 , via OnePlus 7 , Oct 12, 2019 :
    Can tell me anyone ,why on my phone my currently System os is OxygenOs version Op7pro_02_BETA_3 ?
    My phoneo not Op7pro , he's Op7. When had beta 2 was ok as Op7 ,but after i get beta 3 ,now shows like that as i wrote. here can see that on screenshot.
  2. docnok63
    Jelly Bean Oct 12, 2019
    docnok63 , Oct 12, 2019 :
    How did you install OB3? Manual flash? Oxygen Updater?
  3. rema5
    Donut Oct 12, 2019
  4. docnok63
    Then it's a typo in the OP7 build. If you're rooted, you can fix by editing the build.prop if it bothers you.
    rema5 likes this.
  5. rema5
    Donut Oct 12, 2019
    I'm not rooted. Phone works as should be,i will wait till comes final version,not beta . And then i will flash new full rom.
    jim.kanaris and docnok63 like this.
  6. jim.kanaris
    Froyo Oct 12, 2019
    jim.kanaris , via OnePlus 7 Pro , Oct 12, 2019 :
    I feel that's what I will do
  7. kramik
    Honeycomb Oct 12, 2019
    Tanaypande likes this.
  8. jim.kanaris
    Froyo Oct 12, 2019
  9. docnok63
    I've been in the GeForce NOW beta program pretty much since it started for my NVIDIA Shield and then on desktop. When I saw on Android Police that NVIDIA released an app that supposedly only works for Koreans, I decided to sideload it and give it a whirl. It works perfectly fine here in Memphis, TN, USA. I very well might be the first American non-NVIDIA employee to be running this app:
    https://www.androidpolice.com/2019/10/11/geforce-now-android-rtx-servers/
    WoW in 4K on my OP7Pro:
    https://t.co/VHBdeEPlBH?amp=1
    Georgeoneplus7pro likes this.
  10. Tanaypande
    Donut Oct 12, 2019
  11. C1566492973084
    Gingerbread Oct 12, 2019
    C1566492973084 , via OnePlus 7 Pro , Oct 12, 2019 :
    so beta 3 definitely seems to be running well.
    multitasking gesture works a lot better, properly activates recent apps on first attempt.
    Dark mode/Dark tone works well with all native Google apps, Instagram and other system responsive dark mode.
    Still wish there was a simple one click quick setting for it like in standard Android 10, heck even GS10 line had the quick setting toggle on Android Pie (9).
    Camera software still needs a little tweaking specially nightscape as I think it use to be better.
    Of course the video camera capability is a whole nother subject that I don't understand. Taking away 4K60FPS from the wide angle lens didn't make sense. I'd even be okay if they didn't include 4K60FPS on the telephoto and just on wide and standard lens... again we all aware it's not a limited hardware it's software from OnePlus because it was on OB1 and worked very well, even while recording. 855 standard Chipset plus the same camera hardware as 7T series, come on OnePlus.
    Well put the battery for a good run tomorrow to see if there are improvements made there, including bringing back old speeds of warp30
    thanks again for the update.
    sarahmic and VaibhavBhargava like this.
  12. jim.kanaris
    Froyo Oct 12, 2019
  13. Deactivated User
    Oct 12, 2019
    docnok63 and jim.kanaris like this.
  14. sarahmic
    sarahmic , Oct 12, 2019 :
    Excellent comments - well done!
    Will wait for your battery assessment as this is very important - thank you again!
  15. jim.kanaris
    Froyo Oct 12, 2019
    docnok63 likes this.
  16. SamLoth
    Cupcake Oct 12, 2019
    SamLoth , Oct 12, 2019 :
    Hey ! Since i install OB3, my phone get stuck in a bootloop every 2 minutes after enter my password. I search a solution but i'm not an expert in this and i'm afraid cause i really don't know what to do...
    I've tried to wipe cache, but without success, every 2 minutes it reboot and again and again.
    (sorry for my poor english i'm french and i try to find something or someone to help me)
  17. askvbsdkj
    askvbsdkj , Oct 12, 2019 :
    same problem
  18. SamLoth
    oh, i don't feel alone anymore it's good to read this... Did you think we "just" have to wait for any solution ?
  19. U1561481941717
    Cupcake Oct 13, 2019
    U1561481941717 , Oct 13, 2019 :
    Additionally, it will not allow me to downgrade back to update 2. What is our resolution?
  20. narceoneplus2
    Ice Cream Sandwich Oct 13, 2019
