337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. OnePlusAim
    Honeycomb Sep 18, 2019
    OnePlusAim , Sep 18, 2019 :
    His issue was the Camera has recording at 4K by default in new update only 1080p supports all Lenses
    fcarmona likes this.
  2. atLeeroyJenkins
    Gingerbread Sep 18, 2019
    atLeeroyJenkins , Sep 18, 2019 :
    Open Beta 2 is much much better, much snappier, the jank and random freezes are a lot less, still happen under very heavy use (wasn't on Pie) but I'd consider this a near release candidate. It's very stable. No crashes, no problems just a tiny bit of jank here and there that's it.
    3 criticisms:
    1. Please for the love of God adopt the Android 10 style of icons with the outlines, the Pie aesthetic mixed with 10 just looks odd and inconsistent.
    2. Why is the Android 10 gesture navigation sensitivity option gone? It makes no sense removing it and on my work Pixel devices I found it extremely important in adjusting it to preference.
    3. The Incostistant dark theme needs to be fixed. Some areas are black (which it should be) and then some like the drop-down menu is dark gray.
    All in all it's great and I have a feeling next update will be the release.
    Cheers
    Pokemon Master Leeroy
    gizmo91_, anubis72, Shalin235 and 2 others like this.
  3. Matteo.16
    Matteo.16 , Sep 18, 2019 :
    I will not root my device just to use substratum. And Yes, it is oneplus fault, one the OnePlus 7 the colour is fine. On the Google pixel the colour is fine. So...why the 7Pro has this two colours for the notification?
    docnok63 likes this.
  4. Georgeoneplus7pro
    Jelly Bean Sep 18, 2019
    Georgeoneplus7pro , Sep 18, 2019 :
    Clean installation involves returning to factory settings with or without clearing internal memory.
  5. siddartha. ps
    Froyo Sep 18, 2019
    OnePlusAim likes this.
  6. piyushkandge
    Donut Sep 18, 2019
    D H V S Sastry likes this.
  7. siddartha. ps
    Froyo Sep 18, 2019
    dinbandhukumar likes this.
  8. pritamashwani
  9. dinbandhukumar
  10. DnnyKlnr
    Cupcake Sep 18, 2019
    DnnyKlnr , Sep 18, 2019 :
    having same problem, can also swipe up (home) then open from the running apps. not sure if it works with navbar haven't tried it
  11. OnePlusAim
    Greatest Thread Post!!
    siddartha. ps likes this.
  12. erikg80
    Froyo Sep 18, 2019
    erikg80 , Sep 18, 2019 :
    Am I the only one having the Theming issue where nuanced dark is my selected theme but it continues to randomly switch to a light theme? I was hoping it would have been fixed in Beta 2 but it didn't last 1 day before auto switching again... I've reported this bug, had anyone else?
  13. A1563025696415
    A1563025696415 , Sep 18, 2019 :
    wide angle video is missing in the open beta for me. read a couple of articles mentioning its been added in the update.
  14. aduseida
    aduseida , Sep 18, 2019 :
    Both betas have been very unstable in terms of Bluetooth. I cannot even put my OP7 in my pocket while listening to Spotify on my Sony WH-1000MX3 or else the audio will screech to a halt.
    Anyone having this issue?
  15. OnePlusAim
    Anyone Having Issues Connecting Their Phone to their Computer Via USB and Using it as a Storage Device?
  16. Sundar_priyatham
    Eclair Sep 18, 2019
    Sundar_priyatham , Sep 18, 2019 :
    everything is good ..but the bar below keyboard is annoying and irritating ....and animation for recent apps is to be imrpoved..
  17. Georgeoneplus7pro
    Will there still be a useless OnePlus 7T 5G? As long as 5G networks are still in experimental tests..
  18. atLeeroyJenkins
    Again, The Keyboard is deliberate, It's the same way on All pixel devices, its way google designed Gboard to keep the keyboard at the same height as it always was. OnePlus cant change the Gboard behaviour
  19. chetannd
    Eclair Sep 18, 2019
    chetannd , Sep 18, 2019 :
    only in 1080p
  20. Jackie3376
    gizmo91_ and OnePlusAim like this.
