337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. Swejuggalo
    Community Bug Hunter Sep 18, 2019
  2. Bryndaen
    Cupcake Sep 18, 2019
    Bryndaen , Sep 18, 2019 :
    AzuLa9713
    1. Notch hiding feature is still missing on OP7.
    2. Battery life has been improved significantly .
    3. Still dark theme is messier in some notifications(May be app incompatibilities)
    4. Bar below keyboard is still there.
    5. Charging speed is slower as it seems. Didnt measure. Just felt when compared to.regular charging speeds.
    This is what I noticed so far.
    Maaan, its effecting me more than it should but I'm glad I found someone who has an issue with the notch hiding problem. Disappointed that the next update doesn't solve it.
    I've also noticed the drop in charging speed every since I moved to OB1​
    Anandu p likes this.
  3. Lunatico
    Jelly Bean Sep 18, 2019
  4. TenGauge
    Donut Sep 18, 2019
  5. RazvanScutea
    Froyo Sep 18, 2019
    RazvanScutea , Sep 18, 2019 :
    Can somebody tell me if the gap between keyboard and lower edge of screen is as big as in OB 1 ?
    thanks!
  6. Swejuggalo
    Swejuggalo , Sep 18, 2019 :
    My phone was European. My VoLTE and stuff kept on working despite being added only on the EU firmware. So I guess it's universal or something. DPs and betas does not seem to have 2 builds.
    docnok63 likes this.
  7. Swejuggalo
    Same I guess. Google design
  8. JeremyGriffiths
    Froyo Sep 18, 2019
    JeremyGriffiths , Sep 18, 2019 :
    Seems ok for me? Buds & watch
  9. Varun jp aps
  10. Swejuggalo
    My VoLTE still works on OB2.
    And I verified that the files for both EU and International is identical in Oxygen Updater.
    docnok63 and Lunatico like this.
  11. Dgafking0480
    Ice Cream Sandwich Sep 18, 2019
    Dgafking0480 , Sep 18, 2019 :
    mymVoLTE has been working as well
  12. Borijess3
    Froyo Sep 18, 2019
    Borijess3 , Sep 18, 2019 :
    I installed this and it fixed my issue. I don't understand why nobody else is complaining about this. Thank you for the YouTube Vance advice!
    Swejuggalo likes this.
  13. rahulsipu
    Froyo Sep 18, 2019
    rahulsipu , Sep 18, 2019 :
    1. status bar display not showing while open the app lunch apart from dark mode on.
    2. unable to open App to display in full screen .
  14. chidishkush20
    Eclair Sep 18, 2019
  15. Borijess3
    Froyo Sep 18, 2019
    auto rotation is still not working correctly. I use the app rotation and it seems to work on the first rotate but when I try to rotate a second time within the same app it stops working.
  16. Ashwin9417
    Froyo Sep 18, 2019
    OnePlusAim likes this.
  17. Swejuggalo
    chidishkush20
    Can no longer record videos with the wide lense in beta 2​
    You can. But it's redesigned to better let you know it's only recording in 1080p, so it is only visible in 1080p mode
  18. Pasier89
    Donut Sep 18, 2019
    Pasier89 , Sep 18, 2019 :
    Switch to 1080p....
  19. OnePlusAim
    Honeycomb Sep 18, 2019
    OnePlusAim , Sep 18, 2019 :
    thanks bro app is called Black Wallpapers
    Ashwin9417 likes this.
  20. Lunatico
    Lunatico , Sep 18, 2019 :
    THX! BTW...I've tried to get an answer on this question before cuz the original beta post was unclear but do you know if the data gets erased if i update from stable to OBP2P
