337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. Swejuggalo
    KitKat Sep 19, 2019
    Swejuggalo , Sep 19, 2019 :
    Maybe too soon after disconnecting it. It needs stats to do a calculation
  2. CATTLEJOCK23
    Cupcake Sep 19, 2019
    CATTLEJOCK23 , Sep 19, 2019 :
    yep same here no beta 2 for me yet
  3. O1568113000158
    Eclair Sep 19, 2019
  4. Amitp1998
    Honeycomb Sep 19, 2019
    Amitp1998 , Sep 19, 2019 :
    I haven't received open beta 2 yet, please tell me how to download it manually because I also tried to download from oxygen updater but there also showing that your system is updated ....where j can download please help
  5. CATTLEJOCK23
    yep same here no beta 2 for me either
  6. Swejuggalo
    KitKat Sep 19, 2019
    Ah I see. I thought about applying for the normal closed beta here but I chickened out. The available time and the amount of usefulness I could provide is hard to predict.
    Open Beta is less demanding so I desided to be lazy
    docnok63 likes this.
  7. kikuchanjzh
    Eclair Sep 19, 2019
  8. Footneek
    Footneek , Sep 19, 2019 :
    The phone downloaded it all by itself and asked to install yesterday in AM. It's OTA. I guess they are rolling it out in waves. it's pretty small at 133 MB. You should get the update soon.
  9. Swejuggalo
    KitKat Sep 19, 2019
  10. Swejuggalo
    KitKat Sep 19, 2019
    Checked the right settings?
  11. Amitp1998
  12. F1557378530519
    F1557378530519 , Sep 19, 2019 :
    Hey guys! Any way to update from stable to beta without losing all data? Or at least a proper way to fully back up all apps & data? I don't wanna lose google notes, photos, downloads, etc.
  13. Footneek
    Going forward should not affect your data. Going back to stable will definitely wipe it. If data is important to you then I would wait a few weeks.
    F1557378530519 likes this.
  14. jatin0990
    Gingerbread Sep 19, 2019
    jatin0990 , Sep 19, 2019 :
    aa jaega bhai aaj kal me ruk ja
  15. chetannd
    Eclair Sep 19, 2019
    VaibhavBhargava likes this.
  16. Amitp1998
    if I want this update under system updates than which vpn or country should I choose to get this update .
  17. Atanu Maji
    Atanu Maji , Sep 19, 2019 :
    Is anybody getting thermal throttling?
    While charging phone heats up to 39°C and open cameras for 5 minutes temperature goes up to 37°-39°. Also occuring occasional heating while having multiple apps (5-10) running in the background and then battery drains as usual faster. After updating to OB 2 had cleared cache from recovery for once.
  18. Amitp1998
    is there any changes regarding to performance or any under gaming section ....I'm facing some bugs and crashes while playing games in open beta 1 ...is there any improvement occur ??
  19. jatin0990
    still working fine
  20. Amitp1998
    I'm in beta 1 and facing heating issues while using my phone very normally no heavy games
