337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. Y1568142156377
    Cupcake Sep 19, 2019
  2. SoumyaSN
  3. R1567887840766
  4. Midhuntv009
    Midhuntv009 , Sep 19, 2019 :
    Not able to record ultrawide and telephoto video in 4k in new open beta 2 update, please fix this issue
  5. Sajidur Rahman
    Eclair Sep 19, 2019
    Sajidur Rahman , Sep 19, 2019 :
    Then open it from #1321 no comment
  6. docnok63
    Jelly Bean Sep 19, 2019
    fcarmona and Georgeoneplus7pro like this.
  7. Sajidur Rahman
    Eclair Sep 19, 2019
  8. Sajidur Rahman
    Eclair Sep 19, 2019
    https://otafsg1.h2os.com/patch/amaz....10_OTA_009-010_patch_1909112326_deadb1ff.zip use this it is working
    SoumyaSN likes this.
  9. Georgeoneplus7pro
  10. Swejuggalo
    Lollipop Sep 19, 2019
    Swejuggalo , Sep 19, 2019 :
    Some info.
    How to update to Open Beta or update beta with Oxygen Updater. All it really does is to help with downloading the file for you. With the correct name and correct directory. All you need to do is to install it when downloaded.
    http://bit.ly/2HTDBRY
    Update/Downgrade your phone with starting from the community app. Step by step video. Some awesome entertainment during the download included. Downgrade file exists in the first post in OB1.
    https://forums.oneplus.com/threads/...-for-the-oneplus-7-and-oneplus-7-pro.1099154/
    http://bit.ly/2lPAkuy
    OnePlusAim likes this.
  11. Sajidur Rahman
    Eclair Sep 19, 2019
    Georgeoneplus7pro
    OK. And I'll buy a 7T Pro. Thank you for the advice.​
    you are most welcome dear
    Georgeoneplus7pro and OnePlusAim like this.
  12. SoumyaSN
  13. Sajidur Rahman
    Eclair Sep 19, 2019
  14. Georgeoneplus7pro
    Georgeoneplus7pro , Sep 19, 2019 :
    I put him an hour in the freezer and now the task has become easy.
  15. OnePlusAim
    Honeycomb Sep 19, 2019
    OnePlusAim , Sep 19, 2019 :
    probably not a good idea with the device made of glass if it gets hot and then you rapidly cool it heat makes things expand it makes them contract you can crack the glass I do not recommend doing that
  16. NaveenKadali
    Donut Sep 19, 2019
    NaveenKadali , Sep 19, 2019 :
    I want to downgrade from OnePlus Android 10 beta update back to stable pie update, I downloaded the file from OnePlus website but it isn't letting me go back, it says that to avoid booting failure, downgrading is not allowed, how do I go back please tell me
  17. Georgeoneplus7pro
    I don't care anymore, I started to like Beta, he always has good or bad new things.
  18. I1568904753848
  19. Swejuggalo
    Speaking of heat and cooling down... I did a crazy test on my Nokia 8. Nice results on that phone since it was close to a huge heat skink the whole phone.
    I cooled it down at work... Alot. Performance even started to drop and eventually it said it would refuse charging due to too low temperature on battery... While still being running 3dmark in endless loop [e]1f609[/e]
  20. ascent
    ascent , Sep 19, 2019 :
    Seems like ghosttouches like some others at https://forums.oneplus.com/threads/oneplus-7-touch-issues.1070754
    Do you use the supplied case ? That should prevent this, as it's actually triggered by touching the base metal part of your phone
