337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. OnePlusAim
    Honeycomb Sep 18, 2019
  2. AzuLa9713
    AzuLa9713 , Sep 18, 2019 :
    1. Notch hiding feature is still missing on OP7.
    2. Battery life has been improved significantly .
    3. Still dark theme is messier in some notifications(May be app incompatibilities)
    4. Bar below keyboard is still there.
    5. Charging speed is slower as it seems. Didnt measure. Just felt when compared to.regular charging speeds.
    6. Bluetooth icon missing in notification bar.
    This is what I noticed so far.
  3. OnePlusAim
    OnePlusAim , Sep 18, 2019 :
    please Post this in the correct forum
  4. OnePlusAim
    Thank You Very Much :)
    AzuLa9713 likes this.
  5. Q1568527185651
    Cupcake Sep 18, 2019
    OnePlusAim likes this.
  6. TheMysticalShaman
    TheMysticalShaman , Sep 18, 2019 :
    I am still having this issue after this update. When I click on a certain app. Screen goes dark, OP7P freezes. I press and hold power and volume up to reboot. in recent apps, I reopen that app then it works.
  7. OnePlusAim
    Freakyss likes this.
  8. Woodp3ck3r
    Donut Sep 18, 2019
  9. OnePlusAim
    You can record with all 3 Cameras Still if you change to 1080P instead of the Default 4K
    awes0me1 likes this.
  10. rayprayas03
    Gingerbread Sep 18, 2019
    rayprayas03 , Sep 18, 2019 :
    are you using oneplus7 or oneplus7 pro?
  11. antonyjen
    Jelly Bean Sep 18, 2019
    antonyjen , Sep 18, 2019 :
    Nothing like that here for me.. you just try to clear system Cache..may be it can help you!!
  12. kikuchanjzh
    Eclair Sep 18, 2019
  13. Sanil_Mehra
    Sanil_Mehra , Sep 18, 2019 :
    Will. U please elaborate correct forum means
  14. OnePlusAim
    pay close attention most of the time when the screen goes dark it hasn't actually Frozen if you use the gestures if you swipe up to go to your recents or you swipe to go home you can normally swipe back up to the recents and click on the app that black screens and then be able to interact with it but I have ceased this issue since ob2 perhaps wiping and starting over fresh will fix your issue
  15. OnePlusAim
    This Post is Hosted in the OnePlus 7 Series Forum Not the OnePlus 6 Series
  16. TheMysticalShaman
    that do help. The only thing I can think of is. The app has issues with Android 10. Possibly the developer needs to update the app. also had same issue with the My Vegas slots app from the play store.
    antonyjen and OnePlusAim like this.
  17. giannishalde
    Donut Sep 18, 2019
    giannishalde , Sep 18, 2019 :
    The " hidden navigation buttons choice " not fixed yet. Are still too transparent when you have the dark mode.
  18. OnePlusAim
    Well let's find out :) What Apps Cause you these issues? I can test on my end aswell no problem
  19. OnePlusAim
    Thank You
    pratzzz likes this.
  20. TheMysticalShaman
    I don't use gestures. Wiping and reinstall isn't an option. I don't have a way to backup. I have no PC. I don't want to reinstall everything. I prefer to do my 3 step fix. Although it is a pain. Not as much as a pain as reinstalling everything
