337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. Midhuntv009
    Cupcake Sep 19, 2019
    Midhuntv009 , Sep 19, 2019 :
    Not able to record ultrawide and telephoto video in 4k in new open beta 2 update, please fix this issue
    Georgeoneplus7pro likes this.
  2. R1547348730470
    Froyo Sep 19, 2019
  3. prodigalgeniusmark101
    prodigalgeniusmark101 , Sep 19, 2019 :
    If i follow the steps to update my device to android 10 beta it will not get wiped right? it should be just like a normal update, relatively...
  4. 2020marioandrei
    2020marioandrei , Sep 19, 2019 :
    Hello! I have a single serious issue with the main camera app since the beta 2 update: in dark scenario when I try to tap and focus - the LED does not turn on at all only when I actually tap to take the picture it lights up and floods everything in out of focus.. I'm saying it's a software issue because I tried other camera apps and they work fine.
    I've cleared everything on the app, even disabled and enabled again, restart phone, cleared data again.. same issue.. I will try a factory reset later and come back.
    Thank you in advance if anyone has any ideas! My device is One Plus 7 Pro
  5. N1568015924221
  6. umeraiyubi
    Gingerbread Sep 19, 2019
  7. mayekarparag
  8. AzuLa9713
    Honeycomb Sep 19, 2019
    AzuLa9713 , Sep 19, 2019 :
    received on same day. running super smoothly
  9. dickiedrummer
    Donut Sep 19, 2019
    dickiedrummer , Sep 19, 2019 :
    Beta is a pre-release version for testing, probably with bugs, before a stable release is available. You should only really upgrade if you are aware of and prepared for the possibility of having some issues. If not, best to wait.
  10. mayekarparag
    mayekarparag , Sep 19, 2019 :
    I can't see, can you pls share the screenshot
  11. zed sharma
    zed sharma , Sep 19, 2019 :
    when will stable version gonna be released??
    or android 10 will remain in development stage
  12. G_Morad_Hajaliloo_WXAt
    docnok63 and Covrivov like this.
  13. MKaderco
  14. Alpha Mike Foxtrot
    KitKat Sep 19, 2019
    Alpha Mike Foxtrot , Sep 19, 2019 :
    Anyone facing problem when it comes to setting a notification tone for WhatsApp messages?
    Every time I try it I get system crashed error.
  15. Z1564815473473
    Donut Sep 19, 2019
    Z1564815473473 , Sep 19, 2019 :
    download the oxygen downloader from Play store then run for latest version u will able to download it
  16. Umadaan17
    Donut Sep 19, 2019
    Umadaan17 , Sep 19, 2019 :
    in open beta 1 we could see the Bluetooth icon when it was on and connected in status bar but after the update we cannot see it
  17. Sahil_1415
    D H V S Sastry likes this.
  18. Z1564815473473
    Donut Sep 19, 2019
  19. MKaderco
    MKaderco , Sep 19, 2019 :
    thanks man .
    but why there is no links here for beta 2
  20. R1547348730470
    Froyo Sep 19, 2019
