337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. Thulasiraman_Ashokkumar
    Cupcake Sep 19, 2019
    Thulasiraman_Ashokkumar , Sep 19, 2019 :
    I think incremental update and beta update are two different updates, you have to download beta update from oneplus site or through oxygen updater and incremental update is different and will be recived via OTA
  2. VaibhavBhargava
    Lollipop Sep 19, 2019
    VaibhavBhargava , Sep 19, 2019 :
    No they are not.
  3. Thulasiraman_Ashokkumar
  4. pablofg1978
    Spanish POC Assistant Head Moderator Sep 19, 2019
    pablofg1978 , Sep 19, 2019 :
    please don't spam the thread
  5. WooCash95
  6. NvmMan8532
    NvmMan8532 , Sep 19, 2019 :
    I haven't gotten the update yet or notification for the update.. I'm not sure why... also it would be great if the keyboard was a little lower .. and the gestures can be annoying when using apps like discord.. where we need to pull the side... try to better integrate the gestures with the apps..
  7. VaibhavBhargava
    Yes, that's the full OTA/build. But, if someone is updating from an older build (of the beta branch), they will receive only the incremental update, if that fails then the full OTA is received.
    Sometimes OnePlus releases full OTAs only and no incremental updates. Therefore, I was asking whether they released an incremental update or a full update.
  8. Franzim
    Franzim , Sep 19, 2019 :
    how do I download the beta 2? I already have the first on but there doesn't seem to be an update. Already checked oxygen updater but it says im up-to-date too.
  9. VaibhavBhargava
    In the Bluetooth settings menu are you able to see or gauge the battery level of your Bluetooth device ? (assuming your headphones support this feature)
  10. Sai KrishnaD
    Gingerbread Sep 19, 2019
    Sai KrishnaD , Sep 19, 2019 :
    Yeah i am able to see the battery percentage
  11. Swejuggalo
    KitKat Sep 19, 2019
    Swejuggalo , Sep 19, 2019 :
    I got the incremental OTA the same time I saw it on Oxygen Updater.
    VaibhavBhargava likes this.
  12. WooCash95
  13. Thulasiraman_Ashokkumar
    If you have oxygen updater it has 4 types of update for one plus, which are full update, incremental update, open beta full update and open beta incremental update. In that app I can see one plus has released open beta full update.
  14. ranaharishdev
    Eclair Sep 19, 2019
  15. Swejuggalo
    KitKat Sep 19, 2019
    Verify your settings on Oxygen Update. It needs to be on the beta path.
    How to update to Open Beta or update beta with Oxygen Updater. All it really does is to help with downloading the file for you. With the correct name and correct directory. All you need to do is to install it when downloaded. http://bit.ly/2HTDBRY
  16. RajulaRreddy
  17. Franzim
    thanks that worked!
  18. VaibhavBhargava
    OnePlus will always release the full sized OTA, there is no need to point that out.
  19. VaibhavBhargava
    OOS doesn't supports 3rd party fonts
  20. G_vennavalli_ashok_rstl
