337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. techfreak243
    Froyo Sep 19, 2019
    techfreak243 , Sep 19, 2019 :
    I still would like to see the true Android 10 Easter egg. you should put that in if you're using Android 10.
  2. Thulasiraman_Ashokkumar
    Cupcake Sep 19, 2019
    Thulasiraman_Ashokkumar , Sep 19, 2019 :
    Full sized OTA is not the same as Full sized beta update
  3. H1561960043803
    Ice Cream Sandwich Sep 19, 2019
    H1561960043803 , Sep 19, 2019 :
    zed sharma
    when will stable version gonna be released??
    or android 10 will remain in development stage
    noneya.. did you not see my post? don't ask when something will be released
  4. Swejuggalo
    KitKat Sep 19, 2019
    Swejuggalo , Sep 19, 2019 :
    I'm not really sure what function you are missing... The over view of opened apps?
  5. VaibhavBhargava
    Lollipop Sep 19, 2019
    VaibhavBhargava , Sep 19, 2019 :
    Again, OTA means over the air update it can be a full sized update or it can be an incremental update.
    An OTA can be a beta build or a stable build.
  6. VaibhavBhargava
    Maybe he is talking about Normal Clear vs Deep Clear (Recen App Management)
  7. Imangeshgawade
  8. techfreak243
    Froyo Sep 19, 2019
    you should see 9.5.13 if your using the international GM21AA version
    R1567005184462 likes this.
  9. G_vennavalli_ashok_rstl
    Gingerbread Sep 19, 2019
    G_vennavalli_ashok_rstl , Sep 19, 2019 :
    yep i dont like using third party app greenify
  10. akks
    Jelly Bean Sep 19, 2019
    akks , Sep 19, 2019 :
    9.5.13 is just a minor regional update only for Verizon carrier region, literally same otherwise as 9.5.11. Everywhere else 9.5.11 is the latest stable build
  11. Lunatico
    Lunatico , Sep 19, 2019 :
    #Facepalm
  12. L1560462503841
    Donut Sep 19, 2019
    L1560462503841 , Sep 19, 2019 :
    I still have an issue with black screen at launching games! and some problems with WhatsApp video calling.
  13. Swejuggalo
    KitKat Sep 19, 2019
    Ah... But alot complain about Oneplus killing of process too quick [e]1f609[/e]
    The battery parts is slightly redesigned in 10. Intelligent control is new for example.
    I never used deep optimization. I used Naptime.
    Setting the apps to optimize helps too
    VaibhavBhargava likes this.
  14. C1558448081604
    C1558448081604 , Sep 19, 2019 :
    try download OB2 using oxygen updater
  15. VaibhavBhargava
    I was going to point that out, but that complain was regarding the regular Normal Clear and not the Deep Clear optimisation.
  16. VaibhavBhargava
    In that case you should create a bug thread. As this is definitely not a connectivity issue between your phone and the device.
  17. fidus62
    fidus62 , Sep 19, 2019 :
    Versuch es mit VPN Deutschland oder Kanada...
    docnok63 likes this.
  18. Gorakh Raj Joshi
    Eclair Sep 19, 2019
    Gorakh Raj Joshi , Sep 19, 2019 :
    No but I found this problem because of previous interrupted factory reset. I this working again after resetting this device. Now Netflix is working.
  19. Gorakh Raj Joshi
    Eclair Sep 19, 2019
    Footneek
    Netflix working for me. Beta 2.​
    I found this problem because of previous interrupted factory reset. I got this working again after resetting this device. Now Netflix is working.
    Thanks.
  20. Gorakh Raj Joshi
    Eclair Sep 19, 2019
    nateavi
    disable it. clear the cache. then enable it back on.
    head back to the playstore. you should find an update.
    install. run. should fix it.​
    Thanks for your suggestions too.
