337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. H1561960043803
    Ice Cream Sandwich Sep 19, 2019
  2. MD Tausif Alam
    Cupcake Sep 19, 2019
  3. BR7
    Donut Sep 19, 2019
    BR7 , Sep 19, 2019 :
    seems like a pretty solid statement coming from a guy that doesn't even know how to punctuate their sentences.
  4. G_Karel_Čapka_wnEW
    Froyo Sep 19, 2019
  5. Bernest44
    Gingerbread Sep 19, 2019
    Bernest44 , Sep 19, 2019 :
    That makes me wanna do it! Have you heard more?
    OnePlusAim likes this.
  6. G_Karel_Čapka_wnEW
    Froyo Sep 19, 2019
    G_Karel_Čapka_wnEW , Sep 19, 2019 :
    do you have same issue, that in Android 10 battery apps like GSam, Antutu, AcuBattery and other stopped working?
    they will show the status of the time when they are opened and then stopp working. :(
  7. KishMaroli
  8. Swejuggalo
    KitKat Sep 19, 2019
    Swejuggalo , Sep 19, 2019 :
    OTA from OB1? Probably some kind of limited roll out the first days. If you are eager to update use Oxygen Updater. Just make sure to configure it to use the beta channel.
  9. H1561960043803
    H1561960043803 , Sep 19, 2019 :
    D1568730617970
    Im surprised you read my response considering you didn't bother to read the thread and know not to ask the same stupid question that's been asked 100 times atleast. There is no answer and thank you for the grammer lesson. It's easy to get sloppy
  10. E1568837816730
  11. G_Sujith_S
  12. Georgeoneplus7pro
    Jelly Bean Sep 19, 2019
    Georgeoneplus7pro , Sep 19, 2019 :
    Have you installed clean Beta 2 with wipe factory settings? I observe that are you satisfied with the battery and to me it is consumes quickly. In DP5 the battery consumption was excellent, Beta1 higher battery consumption and now Beta2 is much higher
  13. Swejuggalo
    KitKat Sep 19, 2019
    How to update to Open Beta or update beta with Oxygen Updater. All it really does is to help with downloading the file for you. With the correct name and correct directory. All you need to do is to install it when downloaded. Users without root normally only need full update when changing from 9 to 10. http://bit.ly/2HTDBRY
  14. Swejuggalo
    KitKat Sep 19, 2019
    Nope. Wiped at OB1. Just upgraded to OB2.
  15. salvasad
    Froyo Sep 19, 2019
    salvasad , Sep 19, 2019 :
    why do u have 9.5.13 ? is dat a new update for the pro version ? becose myne is on 9.5.11
  16. Bernest44
    Can anyone confirm that OB2 is allowing TMobile data after install? I'm flashed to 9.5.13 but not unlocked. The first OB1 disabled the sim.
  17. Swejuggalo
    KitKat Sep 19, 2019
    The current stats right now. Does not say much about what I have been doing though. But the average drain is pretty OK.
  18. DJSubterrain
    DJSubterrain , Sep 19, 2019 :
    There's already links for both phones...
    https://www.xda-developers.com/oneplus-7-pro-second-android-10-beta-oxygenos-open-beta-2/
    OOS OB2 for the OnePlus 7 [Full OTA]
    OOS OB2 for the OnePlus 7 Pro [Full OTA]
    OOS OB1 –> OB2 for the OnePlus 7 [Incremental OTA]
    OOS OB1 –> OB2 for the OnePlus 7 Pro [Incremental OTA]
    All from the official source too if you check the urls.
    Just download, place in the root directory and do a local upgrade.
    docnok63 likes this.
  19. Swejuggalo
    KitKat Sep 19, 2019
    Some say they flashed with success despite being locked and some say it did not work...
  20. C1558042839204
