337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. vriesdejoop
    Ice Cream Sandwich Sep 19, 2019
  2. xNixuś
    Cupcake Sep 19, 2019
    xNixuś , Sep 19, 2019 :
    Horizontal light doesn't work just for me? I tested it for messenger, gmail and some other apps. The phone vibrates, I receive a notification, but horizontal light doesn't appear.
  3. vriesdejoop
    vriesdejoop , Sep 19, 2019 :
    can every one stop talking about HORIZONTAL light..... if you want to think up other names call it VERTICAL LIGHT.....
    it had nothing to do with HORIZONTAL....
    it is called HORIZON light
    roryrudy and fcarmona like this.
  4. fcarmona
    Gingerbread Sep 19, 2019
    fcarmona , Sep 19, 2019 :
    SMS works, let me receive more notificacions and will continue the report Mr.
  5. fcarmona
    Nest works
  6. C1552500666767
    C1552500666767 , Sep 19, 2019 :
    please how fix black screen when start pubg mobile ? when click on pubg mobile full freeze and black screen [e]1f621[/e][e]1f621[/e]
  7. SaulVázquez95
    Eclair Sep 19, 2019
  8. fcarmona
    they work.
    try in blue
  9. vriesdejoop
    for me it works, is it useful? no not really, would not miss it if it did not work.....
  10. SaulVázquez95
    Eclair Sep 19, 2019
  11. R_d_M
    Froyo Sep 19, 2019
    R_d_M , Sep 19, 2019 :
    i noticed, digital wellbeing says i have 7.5h SOT, battery stats from oneplus says 5.5h SOT ?
  12. RandyManLB
    Froyo Sep 19, 2019
  13. dr@gon
    Eclair Sep 19, 2019
    dr@gon , Sep 19, 2019 :
    Still as was in OB 1, when clicking on notification and then forwarded to the app, the screen goes black and locks up in total black, screen becomes unresponsive. Can hear normal sounds but cannot see anything but black. The only way to recover is to hold down power button and volume up to reboot or adb reboot. If the notification is ignored and app opened from home screen everything functions normally. So it's the switch to app from notification that's freezers the screen, happens everytime - app = Heroic Magic Duels. (magic Duels goes straight to landscape format, I wonder if that has something to do with it?)
    It happens everytime, go ahead and receive a notification from heroic magic Duels and click on its notification if you want to test.
  14. vriesdejoop
    swipe up from one of the bottom corners of the screen
  15. HARRYLP
  16. Stedy59
    Donut Sep 19, 2019
    Stedy59 , Sep 19, 2019 :
    Please remove yourself from this forum if you don't have 7 or 7pro... Thank you for not asking this again.
  17. docnok63
    Jelly Bean Sep 19, 2019
    docnok63 , Sep 19, 2019 :
    Make sure your installation is correct with this installer which pulls latest adb/fastboot from SDK and installs it them as system-wide commands (can be run from any prompt):
    https://androidfilehost.com/?w=files&flid=126148
    I quoted all of you to show how often the same question gets asked over and over again..........
    If your bootloader is unlocked or you're on Android 9, use the full OTA
    If you're on OB1 and your bootloader is locked, use the incremental:
    https://www.xda-developers.com/oneplus-7-pro-second-android-10-beta-oxygenos-open-beta-2/
    Only rooted users can install fonts via Magisk
    It definitely isn't normal and only started with OB1. To both of you: OP7 or 7Pro?
    I think there have been two reports of people saying they have cell connection even with their SIM locked to T-Mobile on OB2. This would definitely be a change from the DPs and OB1. I'd give it a shot if I were you as long as I had everything important backed up.
    You're international variant bought straight from OP was never SIM locked to TMo so that's why you have no problem with cell service.
    Try changing it to a color you don't want, then changing it to the color you do want a couple of times and then test. This got it working for my friend.
    H1561960043803 likes this.
  18. SaulVázquez95
    Eclair Sep 19, 2019
    SaulVázquez95 , Sep 19, 2019 :
    For me, doesn't work.
  19. F_Calum_Wardlaw_cwgT
    Froyo Sep 19, 2019
  20. H1561960043803
    H1561960043803 , Sep 19, 2019 :
    be patient maybe their plan is to bring everybody up to Android 10 at once you never know. it's a brand new phone I'm sure they'll support it for a little while
