337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. N1568737293705
    Cupcake Sep 19, 2019
    N1568737293705 , Sep 19, 2019 :
    Got my 7 Pro today. Beautiful phone.
    Open box. Started it up.
    No data on straight talk. Check APN. Crap vzwinternet.
    Go to Walmart. Get straight talk sim kit. Switch to ATT sim.
    Logged in. Updated apps and such.
    Downloaded Oxygen Updater. Download OP Beta 1.
    Eat sandwich.
    Reboot. Download OP Beta 2.
    Eat another sandwich.
    Reboot.
    Man this phone is awesome. Haven't run into anything crazy. No black screen on the one game I do play (War and Order)
    Bluetooth, cam, etc working like I think it should.
    Only bummer so far is the Poetic case bottom lip to protect the screen makes the new gestures basically unusable. Wish the target was a tad bigger.
    Also. If anyone knows how to get to recents from home screen using bottom gestures. Thanks. Gonna eat a sandwich.
  2. docnok63
    Jelly Bean Sep 19, 2019
    docnok63 , Sep 19, 2019 :
    Ah, I forgot to add. He did it straight from Customization and not from Settings\Display. If that's what you did, sorry. It was worth a shot.
  3. Maxwell3004
    Maxwell3004 , Sep 19, 2019 :
    Still got issues with setting the theme to dark mode and the settings still reverting back to bright white. pretty annoying. Also now having an issue with swiping up to go home. seemed to be buggy. On the 7Pro
  4. SaulVázquez95
    Eclair Sep 19, 2019
    SaulVázquez95 , Sep 19, 2019 :
    Thanks but the same issue, don't work. It's a bug for me.
  5. AndreRibeiro89
    AndreRibeiro89 , Sep 19, 2019 :
    hi,
    anyone notice that in OB1 it was possible to change lens in video modes 1080p 30 fps and 4k 30fps, now in OB2 its not possible to change lens on 4k 30fps, only possible in 1080p 30 fps.
    it will appear again on final release maybe?
  6. H1561960043803
    Ice Cream Sandwich Sep 19, 2019
    docnok63 likes this.
  7. Plockacherry
    Plockacherry , Sep 19, 2019 :
    Sometimes when I type in eg Snapchat. Gboard shows a green dot and I can't continue to type
    Also when I upgraded(clean) some apps were missing like recorder
  8. RedStamina
    Donut Sep 20, 2019
  9. Nic2112
    Ice Cream Sandwich Sep 20, 2019
    Nic2112 , Sep 20, 2019 :
    Swipe from the bottom left or bottom right corner
  10. docnok63
    Jelly Bean Sep 20, 2019
  11. RedStamina
    Donut Sep 20, 2019
  12. Plockacherry
    Cupcake Sep 20, 2019
  13. docnok63
  14. Nic2112
    I have problems with that too. used to be mostly with full screen games but now it's with any app. I swipe up, the bar moves so I know it picked up on it, but nothing happens.
    Reboot fixes the problem temporarily
  15. RedStamina
    Donut Sep 20, 2019
  16. F_Rivers_Kulash_pcHa
  17. C1566492973084
    Gingerbread Sep 20, 2019
    C1566492973084 , Sep 20, 2019 :
    anyone notice that when you use "Natural" screen calibration instead of " vivid" the lock screen stays on vivid mode and then when you unlock it goes back to Natural setting. not sure if this is a known bug.
  18. RJ_Iyer
    RJ_Iyer , Sep 20, 2019 :
    I'm faced problem in auto rotation ...while reboot the device its rectified....but again face the problem quite some time later....
  19. stevevue
    Eclair Sep 20, 2019
    stevevue , Sep 20, 2019 :
    this is still very poor... hoping this update will fix this issue, or I may have to switch....
    OnePlusAim likes this.
  20. OnePlusAim
    Honeycomb Sep 20, 2019
    OnePlusAim , Sep 20, 2019 :
    I've used it my man I still owe 164$ on my OnePlus7Pro and I'm unlocked they ask for very little info and respond when it's done
