337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. RJ_Iyer
    Cupcake Sep 20, 2019
    RJ_Iyer , Sep 20, 2019 :
    And also facing battery drain issue...when screen in awake mode battery drain very fasty... every 1 percentage for every one minute
  2. OnePlusAim
    Honeycomb Sep 20, 2019
    OnePlusAim , Sep 20, 2019 :
    Right now the Problem is 50/50 I myself have improved battery life. But I've seen A LOT of posts with this complaint and plenty of Reports have been made should be fixed in the next one
  3. RandyManLB
    Froyo Sep 20, 2019
    RandyManLB , Sep 20, 2019 :
    For me that works with the left right nav gestures but not the bottom gestures.
  4. patrick.h.day
    Froyo Sep 20, 2019
    patrick.h.day , Sep 20, 2019 :
    After I installed OB2, I booted into recovery and cleared my cache. Doing that seems to clear up many issues I have when upgrading.
    RandyManLB likes this.
  5. stevevue
    Eclair Sep 20, 2019
    stevevue , Sep 20, 2019 :
    that's bad...
  6. Bernest44
    Gingerbread Sep 20, 2019
    Bernest44 , Sep 20, 2019 :
    I've flashed to international with no issues. 9.5.13 and running strong. Let's see what other mischief I can get myself into. I swear One Plus must laugh and sit back and say "look at the people educating each other". Exactly how they pictured it. Kudos!
    OnePlusAim likes this.
  7. hexaguin
    hexaguin , Sep 20, 2019 :
    What happened to 4K telephoto and wide? As of OB2 I'm only seeing the ability to switch lenses at 1080p. OB1 has 4K for all 3 lenses.
  8. patrick.h.day
    Froyo Sep 20, 2019
    Upgrading a locked handset to OB2 works fine. Mine installed. I have an unlocked handset I need to return because my sister got mad and threw it. I'll have to request that it gets unlocked when I get the new unit.
    docnok63 and OnePlusAim like this.
  9. OnePlusAim
    I ******* love that imagery do you know if you are not unlocked already you will have to go back to the T-Mobile firmware after they give you a message back letting you know that you're good use the unlock app that's baked into the firmware once it tells you that you're permanently unlocked you restart your phone you get a notification at the bottom letting you know that your permanently unlocked again then you can flash over to international then you can upgrade but I've also been told that the phones that are locked on the international firmware do have data on ob2
    D1560965181344 likes this.
  10. Bernest44
    Did you have OB1 already or just go straight to OB2?
  11. sFranKv
    sFranKv , Sep 20, 2019 :
    So I recently installed the Beta 2 for android 10 and the first thing that I did was to remove permissions from apps accessing my location, now the only way ( supposedly ) they get access is when I am actually using the app, now I bet that a lot of people change the location to this but I wanted to ask if anyone has noticed that from time to time when unlocking your phone you happen to get them a quick message from android saying that an app had accessed your location? its just a quick message that stays for probably less than a second.
    Is it android by itself accessing my location or a bug?
  12. OnePlusAim
    thank you for that question I am unaware exactly at this time what that means but it definitely sounds like something that should be looked into thank you for bringing it to everybody's attention
  13. G_Jaffrey_Fung_bpSG
    G_Jaffrey_Fung_bpSG , Sep 20, 2019 :
    I am trying to update to beta 2 under system update. but it's showing no update but I am still on beta 1.
    anyone could help?
  14. OnePlusAim
    there is a link on XDA to download the full thing if you're not getting the update I'm not sure why I read on my phone multiple times and every time I redo it or have to use ob one to recover something that I've broken it probably gives me the update to ob2 try a restart on your phone or just install it manually
  15. G_Jaffrey_Fung_bpSG
    you mean the full beta 2??
  16. K Abdul wahid
  17. Yirong
  18. Bernest44
    Okay....you people just logging in....read thru some pages. This asking for the update is Soo redundant! It's all here....READ!! THANK YOU! [e]1f601[/e]
  19. J1559183086798
  20. K Abdul wahid
