337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. stevevue
    Eclair Sep 20, 2019
    OnePlusAim likes this.
  2. OnePlusAim
    Honeycomb Sep 20, 2019
  3. ToxicPaperCut
    Donut Sep 20, 2019
    ToxicPaperCut , Sep 20, 2019 :
    same here!!! any answer yet?
  4. OnePlusAim
    OnePlusAim , Sep 20, 2019 :
    the screen becomes unusable after I launch the app and it goes black. that's why I have to reboot[/QUOTE]
    for screen has only gone black it has not stopped functioning if you use gestures use your swipe to go home often when it does black screen you do find yourself in landscape mode so you can swipe up from the side of the phone instead of the normal bottom or a top as you would consider it and that should bring you home if you still wish to use the app you swipe up to your app switcher and then click the app again and your screen will no longer be black
  5. RohinBhargava
    Donut Sep 20, 2019
    RohinBhargava , Sep 20, 2019 :
    I am not able to figure out how to enable Dark mode on my OnePlus 7 pro. is there a setting or depends on theme we select?
  6. _Amruth_Vardhan_
    Cupcake Sep 20, 2019
    _Amruth_Vardhan_ , Sep 20, 2019 :
    can you please leave a link to the Open beta 2 ....
  7. OnePlusAim
    go into your settings hit the customization tab right there at the top very easy to miss they'll be a square for you to press that will let you change between the theme options dark is at the bottom if that does not work for you or you cannot find it if you go into developer options going near the bottom there is an option to force dark mode
    _Amruth_Vardhan_ likes this.
  8. ToxicPaperCut
    Donut Sep 20, 2019
    OnePlusAim
    for screen has only gone black it has not stopped functioning if you use gestures use your swipe to go home often when it does black screen you do find yourself in landscape mode so you can swipe up from the side of the phone instead of the normal bottom or a top as you would consider it and that should bring you home if you still wish to use the app you swipe up to your app switcher and then click the app again and your screen will no longer be black​
    I will try this for sure. thanks. and I'm assuming it's still a bug?
  9. M1565406667675
    Eclair Sep 20, 2019
  10. OnePlusAim
    I will try this for sure. thanks. and I'm assuming it's still a bug?[/QUOTE]Yeah, it seems to have been around since OB1 I get it less on OB2 but the Temp Fix still works :)
  11. Ravi BINAVAT
    Ice Cream Sandwich Sep 20, 2019
  12. OnePlusAim
    Search XDA OnePlus 7 Pro Open Beta 2 you will find direct download links
    Ravi BINAVAT likes this.
  13. ToxicPaperCut
    Donut Sep 20, 2019
    Ravi BINAVAT and OnePlusAim like this.
  14. OnePlusAim
  15. OnePlusAim
    lol I always forget about that app Thanks for Helping my Man
    O1568926065889 likes this.
  16. M1565406667675
    Eclair Sep 20, 2019
  17. prem5012002
  18. OnePlusAim
    it's a bug when you first download it just restart your phone and it'll work just fine
  19. OnePlusAim
  20. Q1540003285356
    Eclair Sep 20, 2019
    Q1540003285356 , Sep 20, 2019 :
    It's very difficult to use the swipe up gesture to return to the home screen. It seems that I now need to swipe up at least 2x further than needed before in order to activate it.
