337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. Swejuggalo
    KitKat Sep 20, 2019
    Swejuggalo , Sep 20, 2019 :
    You could try to wipe data on the problematic apps and set them up again
  2. N1558173122614
    Donut Sep 20, 2019
    N1558173122614 , Sep 20, 2019 :
    hope to have it in 60 fps 1080p at least. that would be so cool.
  3. juscozimme
    Cupcake Sep 20, 2019
    juscozimme , Sep 20, 2019 :
    Not a big deal, I realize this is a beta. It worked fine on beta 1.
  4. E1568802125602
    E1568802125602 , Sep 20, 2019 :
    today I installed beta version in my oneplus 7 pro...
    I noticed one thing that in low light and night time camera performance not up to the mark..
    need some big improvement..
  5. Swejuggalo
    KitKat Sep 20, 2019
    I haven't checked the specs of those camera lenses. If they support 60fps I guess it is possible.
  6. Nic2112
    Ice Cream Sandwich Sep 20, 2019
    Nic2112 , Sep 20, 2019 :
    Something small that I miss from Android 10 so far is that when enabling DND mode, I don't see an option to automatically turn it off when my alarm rings.
    On pie it would say "Turn on until 6:00am.tuesday" for example if I had an alarm set at that time.
    docnok63 likes this.
  7. G_Danny_Tsang_YWTg
  8. Swejuggalo
    KitKat Sep 20, 2019
    If you make a schedule
  9. kunal.shukla
    Gingerbread Sep 20, 2019
    kunal.shukla , Sep 20, 2019 :
    Plugged in but can't charge. is it a software but or a hardware issue. haven't faced this issue before.
    T1568364139742 likes this.
  10. N1560630073573
    N1560630073573 , Sep 20, 2019 :
    is anyone seeing an issue with Bluetooth going blind for few seconds? I am using bose soundsport and for few seconds it goes blind.
  11. bigdirtypj
    bigdirtypj , Sep 20, 2019 :
    but when updating to beta 2, does your service work or will it still tell you sim is locked?
  12. E1561007827489
  13. Matt 80
    Lollipop Sep 20, 2019
    Matt 80 , Sep 20, 2019 :
    All beta related issues should be posted in the dedicated beta thread.
  14. D1558582059574
    Froyo Sep 20, 2019
  15. C1566492973084
    C1566492973084 , Sep 20, 2019 :
    seconded definitely not as fluid to trigger as it was in OB1
  16. DnnyKlnr
    DnnyKlnr , Sep 20, 2019 :
    Having problems with the gestures
    Specifically the swipe up and hold gesture, about 75% of the time that i try to do the swipe up and hold gesture it doesn't seem to recognise the hold part of the gesture and it just goes home, i often have to re do the gesture multiple times to get to my running apps. (the phone vibrates as though it worked but then it just goes home)
    If i go to navigation settings and change the navigation method between gestures (left and right) and gestures (bottom) then it will work perfectly for a short time using both settings but then after a short while it ends up with the multitasking gesture not working properly again.
    I never had any issues with open beta 1 and I've tried changing settings for resolution/refresh rate/animation speed and other random settings to see if i can find what causes it but i can't figure it out
    Anybody else experiencing this or is it just me?
  17. C1566492973084
    yea I think multiple people are experiencing this.
  18. Cervantes
    Lollipop Moderator Sep 20, 2019
    Cervantes , Sep 20, 2019 :
    Hi
    Please You read the first post
    The beta or update thread is a thread of questions and/or commentary
    Thread merged
    superplus and N1560630073573 like this.
  19. SadmiSiraj
    Donut Sep 20, 2019
    SadmiSiraj , Sep 20, 2019 :
    guys the camera app has lot of bugs this time. if gets closed when switching modes and the landscape photos are mostly being captured by wide angle lens even when the zoom is at 1x
  20. NOOSHITH_satish
    Froyo Sep 20, 2019
