337
Oxygen OS Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. dinbandhukumar
    Honeycomb Sep 20, 2019
    disruptor85 likes this.
  2. SpartanVissepo
    Froyo Sep 20, 2019
    SpartanVissepo , Sep 20, 2019 :
    Sure you can, you just need to read my friend [e]1f44d[/e]
  3. docnok63
    Jelly Bean Sep 20, 2019
    docnok63 , Sep 20, 2019 :
    As I posted, this got it working for my friend, who I talked into buying an OP7Pro, and it also worked for @Nic2112
    Nic2112 likes this.
  4. Nic2112
    Ice Cream Sandwich Sep 20, 2019
    Nic2112 , Sep 20, 2019 :
    *Comes out of the shadows after being summoned by @docnok63
    Can confirm it works for me on Beta-2, I'm using Google's messaging app instead of the built-in and I do see the horizon lights.
    It won't work if the screen is active (on) but if I send myself a text message (SIM-1 to SIM-2) and quickly hit the power button after hitting send, it will see the horizon light notification. I did change it to purple and then back to blue so I don't know if that was necessary to fix the problem or not.
    docnok63 likes this.
  5. AzuLa9713
  6. RaMi83
    Froyo Sep 20, 2019
    RaMi83 , Sep 20, 2019 :
    hi all, i have a strange issue, everyday after i woke up and start using my phone the half right side of my screen is not responding to the touches, and i have to restart or shutdown my mobile so the screen respond again normlly, anyone facing the same issue?? is it software or hardware issue ???
  7. AzuLa9713
    AzuLa9713 , Sep 20, 2019 :
    Probably hardware. cannot be sure
  8. RaMi83
    Froyo Sep 20, 2019
    its strange thing, its only happens to the right half side and only happens when i start using mobile at morning after i woke up
  9. DA7801
    DA7801 , Sep 20, 2019 :
    Greetings!
    Hey guys I'm currently running the stable version of the OOS 9.5.8
    Was considering switching to BETA program
    Wanted to ask something's
    1. I be able to roll back to stable without data loss?
    2. Is beta version better than Stable in terms of battery life etc?
    3. Will i get official stable updates after flashing BETA rom
    Thank you :)
    ankurgpa likes this.
  10. Nic2112
    Inside get an interesting bug while testing horizon lights.
    I sent "test" from sim 1 to sim 2 and received it fine. I replied "okay" from sim 2 to sim 1 and received the same sms 3 times.
  11. Nic2112
    1. No.
    2. No.
    3. No.
    docnok63 and DA7801 like this.
  12. DA7801
    So why do people switch to beta?
    It must be good for daily use
  13. Nic2112
    Well, not being able to go back to pie without wiping all data is not a huge issue for some. My music in on the cloud, so are my pictures, the only hassle is setting up the few applications I need and I'm done.
    Some report better battery life, most report worse, but the impact of that differs. If I was away from a charger all day, I'd care a lot about battery life but I sit at a desk and I have my 20w charger that came with my 6T so I don't care about 4 hours of screen on time versus 6 for example.
    People switch purely for nerdy reasons. See Q before anyone else, bragging rights between nerds, seeing the features that are coming before others, and for a lucky few Beta-2 is better than stable so why not.
    DA7801 and docnok63 like this.
  14. docnok63
    That sounds like your phone's hardware is having trouble waking up from deep sleep. I'd do a backup and roll back to stable and see if it happens again. If it does, get your phone repaired/replaced by OP. If not, decided if it's too much of a bug for you to deal with if you come back to OB2 and it occurs again.
    I woke up this morning to new Magisk and Magisk Manager builds:
    https://github.com/topjohnwu/magisk_files/tree/master/canary_builds
  15. R1565547067300
    Donut Sep 20, 2019
  16. AzuLa9713
    2 or 3.
  17. R1565547067300
    Donut Sep 20, 2019
  18. elanglois
    Lollipop Sep 20, 2019
    elanglois , Sep 20, 2019 :
    Once again, we are beta testing the OS for the next phone, the 7T. It will be released with Q and we won't benefit from Android Q until weeks later.
    With the issues of background tasks being killed, Google Assistant not listening with the screen on and other bugs, I'm ready to custom-ROM this thing and be done with OOS.
    Oneplus never changes
    Georgeoneplus7pro likes this.
  19. Nglmna
    Donut Sep 20, 2019
    Nglmna , Sep 20, 2019 :
    After not being able to utilize OB1 cause my phone is T-Mobile locked I installed OB2 and I have to say I'm loving Android 10 so far. My phone seems to be faster although it might all just be in my head.
  20. Georgeoneplus7pro
    Georgeoneplus7pro , Sep 20, 2019 :
    In your opinion Beta2 is perfect and stable. You and your phone only work great. All applications, Bateria, Wifi, VoLTE, GPS, Camera and all the hardware are going well. Probably everyone here is malicious, except you with your super-device. Tell us the your secret: Where did you buy the Super-OnePlus7Pro?
