90
Oxygen OS Open Beta 2 for the OnePlus 7T and OnePlus 7T Pro
  1. ChrisFeuveel
    Gingerbread Mar 28, 2020
  2. K1519455611422
    Cupcake Mar 28, 2020
  3. Vinayak1997
  4. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Mar 28, 2020
    Liehjan , Mar 28, 2020 :
    And, what should a beta tester do now?
    Vinayak1997 likes this.
  5. SteFaNos123
    Froyo Mar 28, 2020
  6. Vinayak1997
  7. Y1579858518839
  8. Liehjan
    Wrong answer, a beta tester should report it... The developers will fix it ;)
    B_Wrath likes this.
  9. Vinayak1997
    Vinayak1997 , via OnePlus 7T , Mar 28, 2020 :
    I am a beta tester,I reported to developer and said to developer to fix it.
  10. Liehjan
    So, why did you open this thread then? Bugs should be reported and discussed in beta thread only!
  11. Vinayak1997
    Liehjan likes this.
  12. Vinayak1997
    where to post beta problem
  13. ZakooosNS
    Eclair Mar 28, 2020
    ZakooosNS , via OnePlus 7T Pro , Mar 28, 2020 :
    ChrisFeuveel
    the dolby EQ is only available on india and global rom, not on eu rom
    if you have the eu firmware and change the lines ro.build.eu true and ro.vendor.build.eu true to "false" in the bulid.prob the equilizer is there again​
    thank you
  14. B_Wrath
    Nougat Mar 28, 2020
    B_Wrath , Mar 28, 2020 :
    Where have you reported to the developer?
  15. Cervantes
    Moderator Moderator Mar 28, 2020
    Deactivated User likes this.
  16. tajushah
  17. Donald Nice
    Honeycomb Mar 28, 2020
    Donald Nice , Mar 28, 2020 :
    1. This is beta branch support thread
    2. Don't ask for eta.
    3. Stable updates are released every two months.
    4. If you want to change to beta install beta manually once.
  18. Gjronyo
  19. Sarpanch_Rohit
    Sarpanch_Rohit , Mar 28, 2020 :
    My oneplus 7t stop charging. i have to restart it to start charging again. it is only 5-6 month old
  20. Vyshak1999
    Vyshak1999 , Mar 28, 2020 :
    @Manu J and optimise the battery department of op 7T. It has quick drain issues not satisfied with battery even in 60hz and moderate usage.
