90
Oxygen OS Open Beta 2 for the OnePlus 7T and OnePlus 7T Pro
  1. Krishu4uhh
    Froyo Mar 20, 2020
    Krishu4uhh , via OnePlus 7T , Mar 20, 2020 :
    Download link is provided up above in the description.
    OnePlus 7T in blue colour
  2. Krishu4uhh
    Froyo Mar 20, 2020
    D H V S Sastry and dalekrebs like this.
  3. Deactivated User
    Mar 20, 2020
    V1580636461274 and dalekrebs like this.
  4. G_Yury_Koltsov_KwaQ
    Gingerbread Mar 20, 2020
    dalekrebs and ChrisFeuveel like this.
  5. Donald Nice
    Honeycomb Mar 20, 2020
    Donald Nice , Mar 20, 2020 :
    Just install joneplus tools from playstore, give permissions (via adb) and enable call recorder.
    dalekrebs and Deactivated User like this.
  6. ziddey
    Cupcake Mar 20, 2020
    ziddey , Mar 20, 2020 :
    install ob1. then goto system updates to update to ob2
  7. Krishu4uhh
    Froyo Mar 20, 2020
    dalekrebs likes this.
  8. G_Yury_Koltsov_KwaQ
  9. Krishu4uhh
    Froyo Mar 20, 2020
    next beta is available through normal OTA update... go to the system update and check for the update you will find and update of 89mb. do it.
  10. G_Yury_Koltsov_KwaQ
  11. bennyrose
  12. ChrisFeuveel
    ChrisFeuveel , Mar 20, 2020 :
    its the global rom not the eu rom that's exactly what happened to me i made an update to beta 2 via the system settings. i had a eu beta 1 on my eu oneplus7t before. but after the update to beta 2 I have the global rom and not the Eu rom on it
  13. G_Yury_Koltsov_KwaQ
    G_Yury_Koltsov_KwaQ , via OnePlus 7T , Mar 20, 2020 :
    i have global rom beta 1
  14. ananyr
    ananyr , via OnePlus 7T , Mar 20, 2020 :
    i was on joneplus but it had issue
    G_Yury_Koltsov_KwaQ likes this.
  15. Fatih Aşkın
    Fatih Aşkın , Mar 20, 2020 :
    i know, thx but my phone have some issues and not connect to net with wifi or mobile data. can anybody send me a ob 2 global mirror link pls? thank a lot
  16. Akash_Sagar_
    Froyo Mar 20, 2020
  17. ChrisFeuveel
    but understand why I am installing the update to global beta2 on my op7t eu model with eu beta 1 per ota because then the eu beta2 should actually be installed
    aber verstehen muss ich das nicht.
    warum ich auf meinem op7t eu modell mit eu beta 1 per ota das Update auf global beta2 installiert wird da sollte dann ja eigentlich die eu beta2 installiert werden
  18. h1ghland3r
    Froyo Mar 20, 2020
    h1ghland3r , Mar 20, 2020 :
    The OTA for Beta 2 doesn't work here. I needed to download the full file, then install.
    #38
  19. JelleZon
    OnePlus Accessory Tester Mar 20, 2020
    JelleZon , Mar 20, 2020 :
    Wer sagt dass das jetzt die Global Version ist?
    #39
  20. ChrisFeuveel
    die build.prop
    da in der nicht mehr die zeilen
    ro.build.eu true
    ro.vendor.build.eu treu drine stehen ( wie es aber bei der eu beta 1 der fall ist. in der global beta 1 sind die zeillen auch nicht )
    die zeilen kommen nur in der eu firmware / beta dein vor
    #40
