110
Oxygen OS Open Beta 2 for the OnePlus 8 and OnePlus 8 Pro
  1. gubro
    KitKat Sep 24, 2020
    gubro , Sep 24, 2020 :
    Mine are all working.
  2. mel.ok
    Cupcake Sep 24, 2020
    mel.ok , via OnePlus 8 , Sep 24, 2020 :
    Good afternoon, I noticed one bug. Scroll does not work after switching to an open application. For example, I open Instagram, then open any other, go back and the scroll does not work anymore.
  3. C1591752322929
  4. AjeeAB
    Donut Sep 24, 2020
  5. JelleZon
    OnePlus Accessory Tester Sep 24, 2020
    JelleZon , Sep 24, 2020 :
    Playstore drain
    CLEARING the app storage AND UNINSTALLING all app updates in settings fixed the drain for me
    ErynOP, masdaofdesasda and Swejuggalo like this.
  6. AjeeAB
    Donut Sep 24, 2020
    AjeeAB , via OnePlus 8 , Sep 24, 2020 :
    Yes it is.. You would be notified on the procedure
  7. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 24, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 24, 2020 :
    Yepp... But it's only a time until Play Store auto updates. And then it comes back. If you don't manually go in and check it it might give you a few days before it's up to date again.
    JelleZon likes this.
  8. tugsay
    Eclair Sep 24, 2020
    tugsay , via OnePlus 8 Pro , Sep 24, 2020 :
    The battery drains faster than beta 1 and after read the posts here, play store has a role on this problem. Maybe because of the app updates after the OS update I don't know but on my phone play store suck the %18 of the battery...
    n0ahl0wery likes this.
  9. Swejuggalo
    This seems unrelated. Seen other Oneplus phones having the same issue any . Also seen a report on a Samsung device... And that device even the exact same Play Store version.
  10. daavid1995
    Eclair Sep 24, 2020
  11. shubham_117
    Froyo Sep 24, 2020
    shubham_117 , via OnePlus 8 Pro , Sep 24, 2020 :
    Is the low brightness level still too bright ?
    Akshay_0157 likes this.
  12. n0ahl0wery
  13. tugsay
    Eclair Sep 24, 2020
    It seems I have. Want to give it a chance of one day more. After updates, everything can happen on the background. Pollyanna... [e]1f60a[/e]
  14. masdaofdesasda
    Donut Sep 24, 2020
    masdaofdesasda , Sep 24, 2020 :
    I can confirm that works for me to..👍💪
  15. Yannis Neris
    Ice Cream Sandwich Sep 24, 2020
    Yannis Neris , Sep 24, 2020 :
    Its an issue from latest playstore versions...
    Downgrade to older version ..( 21.8.21)...Nonetheless, Google usually fixes this within a few days
    Swejuggalo likes this.
  16. Swejuggalo
    You might need to do it again when Play Store have catched up with you and updated back to the same version again [e]1f609[/e]
    Tried it and manually checked for updates until it was up to date. It updates play store in 2 steps. Last step the drain begins. So until that happens automatically it's all fine.
    Hopefully it does not take long until Google fixes it.
  17. Swejuggalo
    Exactly. It updates itself automatically though. Don't know how often it checks for new updates. But as you say it hopefully does not take long until it is fixed. Until then we may need to downgrade it
