110
Oxygen OS Open Beta 2 for the OnePlus 8 and OnePlus 8 Pro
  1. Jesodes
    Cupcake Sep 27, 2020
    Jesodes , via OnePlus 8 Pro , Sep 27, 2020 :
    Only bug so far Ive noticed, is the bad wifi/mobiledata.
    While playing games, the connection suddenly just disconnects from the internet and throws me out of The game.
  2. Cumir
    Donut Sep 27, 2020
    Cumir , via OnePlus 8 , Sep 27, 2020 :
    In Russian, it looks just disgusting, each inscription on the widget is written in large letters, "СРЕДА" instead of "Среда", hyphenation of the words "Ознакомить ся", or my favorite "КОЛЛЕКЦИИ", he seems to shout, this refers to weather widgets, AOD , it's everywhere, it's a pity that you don't care at all and you won't change anything, and if you do, like with 6t, at the presentation they boasted about the animation of an airplane taking off in quick settings, and then not only removed it (although there is 8) so you still can't solve the freeze problem. I bought 1 + 8 to see what will happen, if the same, you don't make any sense
    1) Disgusting battery life 2) Gray instead of black in most places, as you might imagine, nobody likes it
    Wrote with the help of a translator
  3. nicolaberardino
    nicolaberardino , Sep 27, 2020 :
    ciao, per tornare dalla beta 2 alla stabile, dove trovo il file di rollback per oneplus 8 pro in2023, grazie
  4. rajshah2412
    Honeycomb Sep 27, 2020
    rajshah2412 , Sep 27, 2020 :
    Thanks for the update information @Abdul B.
    Looks like a great update. Can't wait to try it out.
    Thanks to the team for continuously making our experience better.
    SteveCP likes this.
  5. SteveCP
    Jelly Bean Sep 27, 2020
    SteveCP , via OnePlus 8 Pro Onyx Black , Sep 27, 2020 :
    il link è disponibile nel primo post, usa la versione EU said:
    OnePlus 8 Pro EU Version
    utilizzare il collegamento, premere i pulsanti delle impostazioni in alto e scaricare tramite il browser. una volta fatto, potrebbe essere necessario rinominare da .zip.jar a .zip e passare alla memoria interna
  6. Rustum.np
  7. manisahith
  8. Sumit.Singh7
  9. efks
    Ice Cream Sandwich Sep 27, 2020
    efks , Sep 27, 2020 :
    Disable google play culprit
  10. Sumit.Singh7
  11. Rustum.np
  12. O1567020129244
  13. RahulBhambere
  14. C1542618889940
  15. mano@555
    mano@555 , via OnePlus 8 , Sep 27, 2020 :
    Please optimise front camera performance.... it's low light performance is too worse[e]1f494[/e]even not great in sufficient light.
  16. tugsay
    Eclair Sep 27, 2020
  17. nuttawatt
  18. SteveCP
    nuttawatt likes this.
