110
Oxygen OS Open Beta 2 for the OnePlus 8 and OnePlus 8 Pro
  1. SteveCP
    Jelly Bean Sep 27, 2020
    SteveCP , via OnePlus 8 Pro Onyx Black , Sep 27, 2020 :
    If you use Oxygen Updater you can change on to receive Beta updates and you will get OB2 or download OB1 then update
  2. tugsay
    Eclair Sep 27, 2020
    tugsay , via OnePlus 8 Pro , Sep 27, 2020 :
    Thank you, I'll use that app...
    SteveCP likes this.
  3. E1599761055577
    Cupcake Sep 27, 2020
  4. Swejuggalo
    Community Bug Hunter Sep 27, 2020
  5. E1599761055577
    E1599761055577 , via OnePlus 8 Pro , Sep 27, 2020 :
    internal coding should be corrected, switch off will not lead to switch off of alarm.
  6. H1600373861555
    H1600373861555 , via OnePlus 8 Pro , Sep 27, 2020 :
    În modul cameră în modul pro Vreau să folosesc tot zoomul de 30x, acum pot folosi doar 10x și încerc să fotografiez în tot zoomul de 30x pentru lună 🌝
    Vreau să folosesc toate camerele și toate posibilitățile acestei configurări a camerei [e]1f64f[/e]
  7. gubro
    KitKat Sep 27, 2020
    gubro , Sep 27, 2020 :
    Pointless to ask here for updates as nobody here is from OnePlus.
  8. D1595698307982
  9. D1595698307982
  10. KritikaSharma21
    KritikaSharma21 , via OnePlus 8 Pro , Sep 27, 2020 :
    I installed beta version yesterday and after restarting my phone my Amazon app deleted. I have tried almost every way to install it but it's installing. Let me know what I can do
  11. furlan23
  12. Jeji.George
    Eclair Sep 27, 2020
    Jeji.George , via OnePlus 8 Pro , Sep 27, 2020 :
    Download Amazon app apk from apkmirror and install it manually.
  13. KritikaSharma21
  14. Jeji.George
    Eclair Sep 27, 2020
  15. L1595003005665
  16. RajPB17
  17. RayGroundwater
  18. Swejuggalo
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 27, 2020 :
    Can also use Aurora Store.
    https://auroraoss.com/
    A mix of simplicity of Play Store and the benefit of Apkmirror and allowing you to keep the apk stored locally if you wish to uninstall and rollback an app.
    For me Play Store never failed and refused to update apps.
    Longer back I have had to force stop it and reopen or wipe data of Play Store though since it kind of got stuck. But it always recovered and worked after that.
  19. hoangpvm
    Froyo Sep 27, 2020
  20. Swejuggalo
    hoangpvm likes this.
