110
Oxygen OS Open Beta 2 for the OnePlus 8 and OnePlus 8 Pro
  1. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 27, 2020 :
    Did you do any type of analyse of battery drain? For example have you noticed the pretty heavy drain from Play Store that just happened to come at about the same time as Beta 2?
    That specific issue is from Google. Not Oneplus. Only temporary way to solve it without loosing functionality is to uninstall updates of Play Store. That will win you some time until it updates back up to latest version.
    There are many way to check drain. My favorite way is BetterBatteryStats.
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
  2. Akikrathore
    Cupcake Sep 27, 2020
    Akikrathore , Sep 27, 2020 :
    as they said that for in region you have to wait is it stable to use or should wait?
  3. Yoshish
    Donut Sep 27, 2020
    Yoshish , via OnePlus 8 , Sep 27, 2020 :
    This issue has been pointed out before but I have to say that it still remains on the OnePlus 8, if it was ever fixed to begin with. Anybody else notice how the color tint changes when opening 60Hz apps like YouTube? Upon closing the app, the colors become brighter again. I've also experienced it on Play Store, after your phone is "idle" for roughly 2 seconds. The refresh rate apparently drops to 60Hz and colors get a lot darker but once you touch your screen, it jumps back to 90Hz and the colors become brighter again.
    Please fix this, it's annoying...
    chvzedgar, burakin and EthanMaskie like this.
  4. Meowmixez98
    Eclair Sep 27, 2020
    Meowmixez98 , via OnePlus 8 Pro , Sep 27, 2020 :
    I had an issue making phone calls. On two occasions the person on the other end of the call couldn't hear me. I also couldn't hear them. The call would start out fine contacting customer service and I could navigate their automated system but once I got through to an operator the issue would occur.
  5. Nasir_Alam
    Froyo Sep 27, 2020
  6. smaller
  7. adarsh_vaishnav
  8. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 27, 2020 :
    Do a proper analyze of the battery stats. Something is creating that activity. That should show up as a high drain. For example Play Store drain excessively now. If it does for you (does for everyone basically if Play Store is up to date) uninstall the latest update of if. If you have more high drainers, wipe data of them, reinstall them perhaps or even remove them.
    My favorite tool to analyze is BetterBatteryStats stats.
    disruptor85 likes this.
  9. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 27, 2020 :
    As promised to a user. Here are some battery stats on beta 2. Heavy writer on community app. Mostly reading and writing. Using Firefox with dark modes. Forced dark mode on most that does not support dark modes. Manually selected several apps for 60Hz and some forced to 120 via the app AutoHz. Auto screen brightness. 11h+ SoT possible.
    Disabled bluetooth background scanning. Wifi multi/broadcast filter enabled. Optimize on apps I rarely use. Using webapps when ever possible (Twitter for example).
    Most of time on WiFi or outside with fairly strong signal.
    Probably forgotten something. No root nor special kernel. Just my regular spare time usage.
  10. H1598329262238
  11. Stuclark1975
    Eclair Sep 28, 2020
  12. P1596648314746
    Eclair Sep 28, 2020
    P1596648314746 , via OnePlus 8 , Sep 28, 2020 :
    Respected Sir,
    As we have discussed before for the Oxygen 11 beta 1 , I am facing same problem with updating Application ( Oneplus Gallery, Asphalt 9 : Game ) ,
    However, In setting there I don't see new AOD or Grey Black dark mode theme need to change to pitch black .
    Even, A big problem is a black screen suddenly. Sometimes it feels like my phone got hanged and shows black screen during running screen.
    I have attached a screenshot herewith a step which I mentioned in the comment .
    Support me or Suggest me If anybody facing a same problem..
  13. O1601250845656
    Cupcake Sep 28, 2020
    O1601250845656 , via OnePlus 8 Pro , Sep 28, 2020 :
    The battery drain fast !
    I did the factory reset twice already
    Some one have this too??
    and some one can said why the Google play store drain my battery ? all options in background are off
  14. Tee_Eee_Bee
    Ice Cream Sandwich Sep 28, 2020
    Tee_Eee_Bee , Sep 28, 2020 :
    That would be a Google implementation for gesture navigation. I have the same space on my Pixel 4XL.
  15. M1597548308420
    Corneto and fricsfee_vahab like this.
  16. fricsfee_vahab
