110
Oxygen OS Open Beta 2 for the OnePlus 8 and OnePlus 8 Pro
  1. ritesh808
    Honeycomb Sep 28, 2020
    ritesh808 , via OnePlus 8 Pro , Sep 28, 2020 :
    Just go into the All Apps section in Settings, find Play Store in the list, tap on the 3 dot menu top right > Uninstall Updates.
  2. badday0401
    Cupcake Sep 28, 2020
    badday0401 , Sep 28, 2020 :
    This 2nd Beta is better for my OP8,it's smoother and more responsive than first one.No more overheating problem while I'm using cellular data.
    Good jobs!
  3. SIDD7411
    SIDD7411 , via OnePlus 8 Pro , Sep 28, 2020 :
    yeah bro no amazon apps are working on this oxygen 11 betas
  4. gubro
    KitKat Sep 28, 2020
    gubro , Sep 28, 2020 :
    All my Amazon apps are working. I'm not indian though.
  5. saurya056 , via OnePlus 8 Pro Onyx Black , Sep 28, 2020 :
    Dose anyone have face the issue with NOTIFICATION VOLUME.
    for me call volume is perfect but the sms volume is so slow even I can't here when phone is in my hand.
    Please suggest if anyone have solution
    anmol.butta likes this.
  6. SIDD7411
  7. gubro
    KitKat Sep 28, 2020
    gubro , via OnePlus 8 Pro , Sep 28, 2020 :
    Probably, but then again, Amazon should update their apps to be compatible with Android 11.
  8. harish vydyam
  9. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 28, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 28, 2020 :
    No. I always disable AOD. Every single percent no matter how small is wasted battery according to me
    gubro likes this.
  10. Swejuggalo
  11. O1601250845656
  12. ChirudeepPSK
    ChirudeepPSK , via OnePlus 8 , Sep 28, 2020 :
    I THINK YOU HAVE GOT THE CANVAS IF NOT PEEK YOUR SELF INTO THIS
    THE CLOCK STYLE TO BE ONLY DEFAULT AND THUS YOUR WALLPAPER SHOULD BE AFFORDED FOR A PORTRAIT PIC WILL BE ADMIRED ... IF THE WALLPAPER IS LANDSCAPE IT WONT LOOK THAT MUCH GOOD ......
  13. Swejuggalo
    There are usually many different possible errors by this. For me it works. But for some it don't no matter what they do apperently.
    Normally any of these solutions work.
    https://support.google.com/googleplay/answer/7513003?hl=en
    But some users didn't solve it until factory reset.
    I did a factory reset at Developer Preview 3.
    You can also use Aurora Store to download and update apps.
    https://auroraoss.com/
  14. J1599041728019
  15. ChirudeepPSK
    EVEN IN MOST OF THE COUNTRIES HAD NOT ACTIVATED 5G . HOPEFULLY WAIT UNTIL YOU GET 5G . THEN WE WILL BE HAVING A UPDATE ON THIS 5G PORTABILITY.....
  16. ChirudeepPSK
  17. uvrx
    Eclair Sep 28, 2020
  18. M1599811299986
  19. Swejuggalo
    It updated back to the newest strait away for you?
