110
Oxygen OS Open Beta 2 for the OnePlus 8 and OnePlus 8 Pro
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 24, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 24, 2020 :
    Sometimes you may need to do some investigation of why and what that drains. Sometimes there is a easy fix. Sometimes harder. Sometimes you actually need a clean start to rule out upgrade problems (factory reset and clean install...)
    And ofcourse report it via the feedback tool.
    It's a beta after all.
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    #41
    housry23 likes this.
  2. housry23
    Ice Cream Sandwich Sep 24, 2020
    housry23 , Sep 24, 2020 :
    Not true. I downloaded some wallpapers from an icon pack, and wallpaper apps and canvas worked with them.
    #42
    B1600151390838 likes this.
  3. gauruv
    Gingerbread Sep 24, 2020
    gauruv , Sep 24, 2020 :
    I was facing the same problem. It has to do with the OnePlus Launcher version. Go to Settings -> Apps & Notifications -> OnePlus Launcher and select Uninstall Updates.
    Canvas should appear afterwards
    #43
  4. housry23
    Very true @Swejuggalo also, I've noticed that right now, AOD really is a major battery drain. Not sure if OP can get it better, but if I have AOD on, I get really bad battery life. If I turn it off and go back to ambient display, I get great battery life.
    #44
    Y1591203058250, batho and Swejuggalo like this.
  5. Gav_W86
    Starting Point Expert Community Expert Sep 24, 2020
    Gav_W86 , Sep 24, 2020 :
    have you reported it using the bug report option in the community app?
    #45
  6. #46
    batho likes this.
  7. Kamlesh900
    Donut Sep 24, 2020
    #47
    AndyRM and B1598019997938 like this.
  8. Swejuggalo
    I have always avoided AOD on every phone I ever owned. First thing I turn off. Even if 1% on a day it's still a wasted 1% if you ask me.
    I don't really know how Oneplus do it. For example using 1Hz refresh rate or something or currently something less efficient...
    I'd recommend BetterBatteryStats to compare idle drain. And report via the feedback tool if you consider the drain to be abnormal due to AOD. Even stuff like using Insight or not may have a big effect on idle drain.
    #48
    drl431 and gubro like this.
  9. wawanredblack
    #49
  10. Q1588084225903
    Eclair Sep 24, 2020
    #50
  11. Liehjan
    Marshmallow Sep 24, 2020
    Liehjan , Sep 24, 2020 :
    You should always do a factory reset first, and if that don't help.. rollback
    #51
    gubro likes this.
  12. Q1588084225903
    Eclair Sep 24, 2020
    Q1588084225903 , Sep 24, 2020 :
    Should i do this every time when a new Android version cones out? Or only at an beta?
    #52
  13. mueduer
    Cupcake Sep 24, 2020
    mueduer , via OnePlus 8 Pro , Sep 24, 2020 :
    PostFinance Mobile App (Switzerland) crashes permanently. The App is optimized for Android 11.
    It crashed in OP1 also.
    Deleting and reinstall doesn't help.
    #53
    W1588071021383 likes this.
  14. Misfer
    Misfer , via OnePlus 8 Pro , Sep 24, 2020 :
    Updation for OS 11 beta has done
    But canvas feature on wallpaper is not always on but either u need to lift the phone or tap the screen to view it
    Anyway the feature is cool.
    #54
    Adriamat likes this.
  15. cainw1
    cainw1 , Sep 24, 2020 :
    Installed this morning and seems stable so far. Many thanks for the update
    #55
  16. Swejuggalo
    1. Investigate drain. Look at battery stats. Maybe even use additional tools for extra stats like BetterBatteryStats. Allow the phone to finish a background optimize (via full charge plus X amount of hours connected to charger or running this command via adb shell "cmd package bg-dexopt-job"
    2. Report a issue via feedback tool if you can claim that the issue is caused by OnePlus. Report the issue to the app dev if the issue may lay in the app. Or both if you don't really know.
    3. Look into the problem and see if data wipe or cache wipe, or setting changes of the problematic components helps. Chances are it might fix the problem.
    4. Factory reset with a clean install. A factory reset without importing all settings and app data from Google or a full Oneplus Switch backup may solve an issue if you can't really pinpoint from where and what that causes it.
    5. If solved, or everything you done failed, add that info to bug rapport.
    6. Last resort. Rollback. You gonna loose data anyway.... So why skip step 4.
    https://forums.oneplus.com/threads/...s-and-battery-calibration-myths-busted.993896
    #56
    DameinDmello and B1598019997938 like this.
  17. #57
  18. gubro
    KitKat Sep 24, 2020
    gubro , Sep 24, 2020 :
    Just like the way I see it. AOD is the single most useless feature for me.
    #58
    drl431 and Swejuggalo like this.
  19. C1589530973855
    Eclair Sep 24, 2020
    C1589530973855 , via OnePlus 8 Pro , Sep 24, 2020 :
    It seems that wifi 2.4 ghz slow down and bluetooth connection issues have been fixed! Chapeau oneplus! Black crush still there, but i am sure, it can be fixed by software (gamma).
    #59
  20. Liehjan
    I do it every time a new android version comes out... Have worked for me :)
    #60
