109
Oxygen OS Open Beta 2 for the OnePlus 8 and OnePlus 8 Pro
  1. Huzail likes this.
  2. H1597279423502
    Cupcake Sep 29, 2020
  3. Ranjit2206
    Froyo Sep 29, 2020
  4. thetruthofOp8
    Eclair Sep 29, 2020
    Huzail likes this.
  5. Huzail
    Eclair Sep 29, 2020
    Huzail , via OnePlus 8 , Sep 29, 2020 :
    Bro like they said it's still beta.... When you Install the beta version you agree to all the risks... So give them a lil time they should have the stable version come in soon
  6. Huzail
    Eclair Sep 29, 2020
  7. J1553620729687
    Huzail likes this.
  8. SteveCP
    Jelly Bean Sep 29, 2020
  9. Malte654
  10. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 29, 2020 :
    Second day with the new Play Store after a nightly charge. No drain yet.
    Steps I've taken. Wiped data of both Play Services and Play Store. Using Play Store with Optimized battery setting.
    Not using auto updates of apps. Started using Aurora Store due to the issues but will carry on using it even after since I liked the way it works and the perks it has.
  11. Lakhvinder
  12. vrushab_kaveri
    Donut Sep 29, 2020
  13. X1575286304442
  14. vrushab_kaveri
    Donut Sep 29, 2020
  15. Sonusihag
  16. A1594375094357
  17. parthaurora
    Eclair Sep 29, 2020
    Huzail likes this.
  18. Shank_Ram97
    Donut Sep 29, 2020
    Shank_Ram97 , via OnePlus 8 Pro , Sep 29, 2020 :
    As some of the other users I too experience fast battery drain... From 22 hours to 8 hours... So the major thing which has to be addressed before the stable.... And please bring back shelf to the laft of home screen....it was much more useful than that of Google pane...swipe down is used for notification drawer for a long time,so it doesn't feel right... Atleast give us the option of having Google or shelf on the left pane of homescreen
  19. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 29, 2020 :
    Usually this helps (see link, try ALL). But for some this does not help.
    Some even did an factory reset and got it solved that way. I don't have this issue and I reset at Developer Preview 3. If this is triggered by something like 10 upgrade or something else I don't know.
    https://support.google.com/googleplay/answer/7513003?hl=en
    Alternative solutions is to manually update either via Apkmirror or the alternative store Aurora Store.
    https://auroraoss.com/
