110
Oxygen OS Open Beta 2 for the OnePlus 8 and OnePlus 8 Pro
  1. gubro
    KitKat Sep 24, 2020
    gubro , Sep 24, 2020 :
    Trying to work out what you want to say, but generally the apps are developed by a third party, not OnePlus, so these developers can make their app compatible with Android 11.
    #61
  2. Liehjan
    Marshmallow Sep 24, 2020
    Liehjan , Sep 24, 2020 :
    Does the apps have A11 support? Do the apps require a certified build?
    #62
  3. housry23
    Ice Cream Sandwich Sep 24, 2020
    housry23 , Sep 24, 2020 :
    I wouldn't call it abnormal. I usually don't use AOD anyway, so I'm with you on that. On the Pixel 4 XL, I didn't use it. It's a major battery killer on it too. I'd rather have Ambient display where I just tap on the screen to see the time and notifications.
    #63
    Swejuggalo likes this.
  4. anmol.butta
    Froyo Sep 24, 2020
    anmol.butta , via OnePlus 8 Pro , Sep 24, 2020 :
    -The text has no color sometimes or maybe it's black on black background.
    -The battery level is not being indicated accurately on the bar in the most recent clock type.
    - Battery optimisation so poor. (6hrs at 66% with basic usage)
    - Some touches take time to respond.
    - Snapchat toolbar on the bottom is coinciding with the home button space.
    #64
    Dinesh_T and JelleZon like this.
  5. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 24, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 24, 2020 :
    I do it everytime a major version update is installed. Like having 10 installed and upgrading to 11. This regardless of having issues or not. Because then I know the issues I will have is because of the installed the version and not because of issues causes by the upgrade itself.
    And ofcourse if having issues you can't solve or if they are serious enough to make you want to rollback. Since rollback wipes anyway... Why not wipe the beta before rolling back.
    #65
    Liehjan likes this.
  6. Swejuggalo
    You might want to force stop Play Store and wipe data of it and see if that battery usage goes away.
    #66
    JelleZon likes this.
  7. JelleZon
    OnePlus Accessory Tester Sep 24, 2020
    #67
    B1598019997938 likes this.
  8. Swejuggalo
    #68
    Bec de Xorbin likes this.
  9. SteveCP
    Jelly Bean Sep 24, 2020
    #69
  10. grymster
    Froyo Sep 24, 2020
    grymster , Sep 24, 2020 :
    Stop spam the thread!
    #70
    Coled3 and elmexiken like this.
  11. Kanji Kher
    Froyo Sep 24, 2020
    #71
  12. Misfer
    Cupcake Sep 24, 2020
    Misfer , via OnePlus 5 , Sep 24, 2020 :
    The canvas feature is cool but either u need to lift the phone or u need to tap the phone view it.
    always on display option for canvas feature is missing.
    Still the low light issues exist but it has reduced considerably
    Issue Like
    While using keyboard
    #72
  13. Liehjan
    The OB1 wasn't certified, so maybe that's the case with OB2 also... GPay needs a certified build to work.
    #73
  14. Liehjan
    So you had no issues on OB1?
    #74
  15. shubham_117
    Froyo Sep 24, 2020
    #75
  16. Swejuggalo
    Was you allowed to register your credit card and payments options? Or is the problem that it does not work in stores? Wiped G-Pay and set it up again? You can even wipe everything inside your Google account.
    Everything works for me in beta 2. Could not pay with it in beta 1. Early in beta 1 it did not allow me to activate contactless payments. But one day it allowed it all the sudden. Probably something done at my bank or something.
    #76
    SteveCP likes this.
  17. SteveCP
    #77
  18. Megh7
    #78
  19. Swejuggalo
    Never any Play Store update issues for me. I did a wipe and clean install at DP3 and have upgraded since then.
    Maybe the Play Store issues that many had (for example updates and downloads getting stuck) was triggered by something via 10 upgrades for example. No normal solution worked it seemed. But those that wiped got it solved.
    #79
    Liehjan likes this.
  20. Piikachu
    Donut Sep 24, 2020
    #80
