110
Oxygen OS Open Beta 2 for the OnePlus 8 and OnePlus 8 Pro
  1. reedmunro
    Cupcake Oct 1, 2020
    reedmunro , via OnePlus 8 Pro , Oct 1, 2020 :
    Update:
    To be more specific, this with chromecast is with Chromecast built-in and Android 11 as I go thr same result on my pixel 2.
    Cast my screen to my chromecast built-in device turns the tv screen black.... Pauses, and then ends the casting session.
    Battery drain is still bad... I used to get over a day on my OP8P now it doesn't even get me to the end of the day.
  2. AndyRM
    Gingerbread Oct 1, 2020
    AndyRM , via OnePlus 8 Pro , Oct 1, 2020 :
    I have had the same message repeatedly. I decided that there was not much wrong with gallery without the update so chose to ignore it. Maybe it will be fixed one day
  3. Z1546248036502
    Cupcake Oct 1, 2020
    Z1546248036502 , via OnePlus 8 , Oct 1, 2020 :
    Not only the gallery also in installing the large files same problem repeats
  4. AndyRM
    Not experienced the problem with large files. Only Gallery.
  5. Z1546248036502
    Cupcake Oct 1, 2020
  6. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 1, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 1, 2020 :
    Report this chromcast issue via the feedback tool.
    Do you happen to have major drain from Play Store?
    At first I thought that Play Store itself was the cause ... But the most recent versions of Play Store works better with a newer Play Services (current beta).
    You can temporary join beta and update it or stay there if you like. Alternatively update via apkmirror.
    https://play.google.com/apps/testing/com.google.android.gms
    razorrahul likes this.
  7. Swejuggalo
    Wish I had a second device with this issue... 😉
    I have not found a permanent and certain solution for this. I can only point to the recommended solution suggested by Google. But it annoys me that those tips does not seem to help.
    https://support.google.com/googleplay/answer/7513003?hl=en
    Thd fun thing is that I found a reason to check out Aurora Store. Can be a alternative solution than just wait and hope for a solution för those that have the update issues.
    https://auroraoss.com
  8. AndyRM
    I've worked through the Google checklist, thought of smart lock myself and under developer options is one that is described as keeping screen on whilst charging. I thought that meant unlocked as well as on - but it does not.
    Like you would not put Aurora on my main device and don't have a secondary Android device.
    What I find so annoying is that feedback is a one-way street with oneplus. An acknowledgment of the issue existing would be helpful. It's not as if I'm done in reporting the issue
  9. reedmunro
    Cupcake Oct 1, 2020
    I am a G play services beta tester and it doesn't seem to the issue. I have been keeping an eye one any potential troublesome apps but I cant seem to pin it down to a specific app. Thanks for the suggestion!
  10. Swejuggalo
    No specifics... Possibly related to what they upgraded from and the last time they wiped or something.
    Edit: BTW... Was thinking on the update issue with Play Store.
    Drain can be tricky. 4G or 5G and how all apps behave. Network stability.
    A full analyze with BetterBatteryStats should show something. But unstanding the results may not always be that easy.
  11. Swejuggalo
    Network related stuff seems more common on IN2025 though. I hear about many Indian issues too. But it's hard to know how many it works well for since happy users usually don't come here just to say how well everything works.
  12. Swejuggalo
    Is it that famous issue when on WiFi at the same time? Or it happens regardless? This issue is so common that even Textra developed a WiFi fix for MMS.
    A other issue that seems to happen for many is that leaving home and disconnecting from WiFi does not auto connect to mobile data of some reason.
    Does not happen for me either.
    kalaljatin likes this.
  13. Swejuggalo likes this.
  14. rajshah2412
    Honeycomb Oct 1, 2020
    rajshah2412 , Oct 1, 2020 :
    Thanks for the update information @Abdul B.
    Looks like a great update. Can't wait to try it out.
    Thanks to the team for continuously making our experience better. #OxygenOS
  15. coreslash
    Froyo Oct 1, 2020
    coreslash , via OnePlus 8 Pro , Oct 1, 2020 :
    What update?
  16. Predict23
    Ice Cream Sandwich Oct 2, 2020
    Taiyeb likes this.
  17. Feredi9
    Cupcake Oct 2, 2020
    Taiyeb and C1589530973855 like this.
  18. R1594578143443
    Cupcake Oct 2, 2020
    R1594578143443 , via OnePlus 8 , Oct 2, 2020 :
    My OP8 is running on Beta2 now. Some issues are there
    1. Screen auto brightness is not correctly picking up, as it ends up setting display brightess near middle of the rang e always.
    2.Some cases scrren is auto rotating(when auto rotate option is off)
