110
Oxygen OS Open Beta 2 for the OnePlus 8 and OnePlus 8 Pro
  1. Gav_W86
    Junior Moderator Junior Moderator Sep 24, 2020
    Gav_W86 , Sep 24, 2020 :
    Google likely haven't certified the build yet.
  2. Gav_W86
    depends on the app. the apps devs may need to update the app for A11, or they may require a certified build, or they may block beta OS, but in general it will be an app issue.
  3. Gav_W86
    A11 is currently only in pre-release beta test - you would have to manually flash to a test build.
    You will get it automatically as full stable build when it is released. No public eta yet.
    Gilles44 likes this.
  4. SteveCP
    Jelly Bean Sep 24, 2020
    SteveCP , via OnePlus 8 Pro Onyx Black , Sep 24, 2020 :
    The first post on this page tells you what you need to know. A clean wipe is required to move back on to the stable path
  5. cls55 likes this.
  6. TemmyMaradilla
    Cupcake Sep 24, 2020
  7. housry23
    Ice Cream Sandwich Sep 24, 2020
    Piikachu likes this.
  8. mueduer
    mueduer , via OnePlus 8 Pro , Sep 24, 2020 :
    You are right with the reviews on PlayStore, but with Android 10 I haven't any issues with OnePlus 8 Pro and Samsung Note 8 before.
    It seems that the most issues are with Xiaomi smartphones.
  9. umair0077
    umair0077 , via OnePlus 8 Pro , Sep 24, 2020 :
    There is a problem with the Android beta 2. As you can see when you open the snapchat the navigation bar covers the snapchat navigation buttons and we are unable to operate the snapchat's gestures in the bottom.
  10. Funk Wizard
    Moderator Moderator Sep 24, 2020
    Funk Wizard , Sep 24, 2020 :
    Merged with Beta 2 thread, please do not open a new thread for beta issues... its a BETA for a reason. Bugs are expected
    MonkeyMouth and SteveCP like this.
  11. SteveCP
  12. SAMSUNGCAMERA1SAPOS , via OnePlus 8 Pro , Sep 24, 2020 :
    hey OnePlus! any way you could copy the code for ASHA hearing aid support from the 7 Plus and put it into a beta as well for 8 Plus? Us deaf or hard of hearing people are trying to wait patiently. I know most people don't have hearing problems, but for those of us that do this could really be a game changer.
    thanks for the consideration!
    Harshil__07 likes this.
  13. TemmyMaradilla
  14. SteveCP
    It is a global firmware so can be used on all carrier unlocked regions however, for Indian users there are certain things missing due to technical problems.
  15. SteveCP
  16. SteveCP
    Please put your request via the feedback tool, this is community based, only moderators visit the forums not OP Devs.
    SAMSUNGCAMERA1SAPOS likes this.
  17. youbi
    Assistant Head Moderator Assistant Head Moderator Sep 24, 2020
    youbi , Sep 24, 2020 :
    Hi, just wanted to let you know that I merged your thread with this one. The truth is that this is the official thread to discuss the latest beta, so this should be the right place to discuss the update or else we would end up with a forum full of repeated stuff.
    Hope you understand, we are here to try and help keeping this place one that everyone enjoys visiting.
    Godfather 1 and SteveCP like this.
  18. r__piyush91
    r__piyush91 , Sep 24, 2020 :
    Has there been any update for the IN version, of the open beta 2 ?
  19. smaller
    smaller , Sep 24, 2020 :
    I bought a new 1P8P, I would like to know if I upgrade to Oxegen 11 Beta 2, later when the stable version released, I need to upgrade manually, or will live update from beta to stable?
    Another question: My device is IN2020, where is a specific Beta version download URL for IN2020?
  20. Christiaan Lemmers
    Christiaan Lemmers , via OnePlus 8 , Sep 24, 2020 :
    Yes dual 5G and 4G works but when you change from 5G sim 1 to sim2 iets gives a message that 5G is not supported on sim2 and on beta1 this worked
